My oven has three halogen interior lights, they are just the small two-pin "push in" type (12 volt from memory).
I'm having to replace them every 2-6 months (presumably because they just get too hot). All that sits between the bulbs and the oven cavity is a plate of glass.
Is anyone aware of better quality bulbs that might be able to stand up to the hot conditions and last longer? Alternatively, is there such a thing as an LED replacement for this application?
What brand of bulbs are you using? They might be Chinesium specials, designed to fail quickly.
My oven uses an incandescent lamp, which has lasted for many years. Recently a service tech replaced the lamp, and I had a look at it before he installed it: Smeg brand, made in Italy, still in production, rated at 300 deg. C (from memory).
Oven lamps are exempt from legislation that phase out inefficient lamps with low lm/W, like incandescents and halogens, for practicality. These lamps are still in production.
The filament temperature is critical. As a practical matter, for long life, you want as low a colour temperature as you can get.
Aircraft incandescent lamps rated at 2E5 hours operate at 2000 Kelvin filament temperature. At 2000 K, tungsten has a vapor pressure that is just measurable - in other words, it's just starting to evaporate. Above 2000K, the evaporation increases dramatically.
Another other wear-out mechanism is grain recrystallization. As the filament heats and cools, its grain boundaries reform, and start aligning with each other (instead of interlocking). This makes the filament more fragile - more likely to break because of thermal or mechanical shock. To reduce this effect, long life filaments use Rhenium tungsten which has a higher recrystallization temperature. But these are more expensive - another reason to avoid Chinese "bargains" and go with a geniune spare part from a decent brand.
http://www.tlt.co.jp/tlt/english/products/industrial_light/miniature_lamp/catalog/info.htmSo, TL;DR: go for a decent brand and low colour temperature.
