Author Topic: Return of the Vacuum Tube  (Read 8735 times)
Offline Sionyn
« on: May 23, 2012, 09:29:56 pm »
is this thing serious i mean sure they have their uses but a return so how i don't think so
i'll never forget my grandad's reaction when even i mentioned vales 'damn valves'
http://news.sciencemag.org/sciencenow/2012/05/return-of-the-vacuum-tube.html?ref=hp
eecs guy
Online PA0PBZ
Re: Return of the Vacuum Tube
« Reply #1 on: May 23, 2012, 10:02:58 pm »
Well, it's not really a vacuum tube is it? It has no vacuum and it has no glass. The only thing simular to a vacuum tube I can see is that the electrons travel freely, not in silicon or some other material. And yes, radiation resistance is a good thing to have, so it looks serious to me.
Offline Time
« Reply #2 on: May 23, 2012, 11:27:37 pm »
Boasting operating frequencies of .46 THz I would say its pretty serious.  Its nano sized in a substrate.  I would say this is nothing like grandpas old valves.
-Time
Offline kaptain_zero
« Reply #3 on: May 23, 2012, 11:45:50 pm »
I've always felt that, much like "smokeless gunpowder", solid state electronics were but a passing fad. Even today, without the nano stuff entering into the picture... when you want REAL rf power, it's glow in the dark technology to the rescue.
Regards
Kaptain "RetroGrouch" Zero
Online vk6zgo
« Reply #4 on: May 24, 2012, 12:22:36 am »
I too, like "FETs with a fire in 'em"---but it looks like they've taken the "fire" away with these new "nano" thingys! ;D
Offline codeboy2k
« Reply #5 on: May 24, 2012, 01:19:19 am »
something like this is very useful, although at 150nm it's large compared to today's features at 22nm and upcoming 16nm.
The article quotes an engineer stating that it's not compatible with today's voltages, and that's true, but I don't see that as a problem. In the past we had 5V, 3.3V, 1.8V, and now 1.2V tech, and even 0.8V; the only reasons we keep lowering the voltages is to allow the gates to switch faster and to reduce the heat generated due to resistive losses in the silicon.  At 10V and crossing a 160nm gap, this technology doesn't have much resistance in air, and so I think very little heat would be generated due to resistive losses.  And if they can improve the technology to reduce the gap size, then the voltages needed to cross that gap can be reduced, and resistance would be reduced even further still.
If this tech goes mainstream, we would just move back to a higher voltage supply, but the advantage would be way faster computing at .46THz (460Ghz).  That's 2 orders of magnitude faster than we can currently achieve with silicon.
Offline CyberWalker
  • Country: gr
  • ...challenges lie among our simplest trivial daily
« Reply #6 on: May 24, 2012, 10:36:45 am »
I agree with kaptain_zero!   ::)
I've been messing with hardware ever since I can remember myself... I always loved hacking the science out of stuff but it was not until the age of 14 that I could proudly present something useful out of it! ;-)
I love technology and anything that includes a sophisticated concept or design! :-)
Offline ejeffrey
« Reply #7 on: May 24, 2012, 02:38:34 pm »
It pretty much is exactly a vacuum tube.  Actually, it has roughly the same amount of air as a traditional vacuum tube -- just in a volume 15 orders of magnitude smaller.
Online PA0PBZ
« Reply #8 on: May 24, 2012, 11:02:10 pm »
Ok, can't argue with that  8)
Online obiwanjacobi
  • What's this yippee-yayoh pin you talk about!?
    • Marctronix Blog
« Reply #9 on: May 25, 2012, 01:37:34 pm »
What a wonderful development! Who cares how it works or what its called, as long as it works and at 460 Ghz I would say it is very useful.
I'm also thinking hybrids: pieces of a die based on current technology (16nm you say! wowzers) and parts of the die working at this new technology. I mean, the rest of the PC is not going to get near that speed anyway (although memory with a 460 Ghz bus would be awesome).
« Last Edit: May 25, 2012, 01:41:00 pm by obiwanjacobi »
Arduino Template Library | Zalt Z80 Computer
Wrong code should not compile!
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #10 on: May 25, 2012, 01:46:48 pm »
I think you meant GHz where you put MHz  ;D. I'm not sure of the claim about a valve computer being faster though. As each valve is a huge switch and you need billions of switches to make a processor that makes for a huge device and lots of long connections with bye bye to the speed. Obviously these things will have their uses.
https://www.simonselectronics.co.uk/shop
Varied stock of test instruments and components including EEVblog gear and Wurth Elektronik Books.
Also, if you want to get ripped off: https://www.ebay.co.uk/usr/simons_electronics?_trksid=p2047675.l2559
Online obiwanjacobi
    • Marctronix Blog
« Reply #11 on: May 25, 2012, 02:18:46 pm »
Hi hi, yes. I changed it now.
Offline T4P
  • Country: sg
    • T4P
« Reply #12 on: May 25, 2012, 02:46:20 pm »
No, Just no.
Offline Ed.Kloonk
« Reply #13 on: May 25, 2012, 02:49:35 pm »
I have to say when I saw the new nutter making those x-ray tubes, my appreacitaion of tubes has changed. To see someone construct a tube with more or less tools I have here makes me more interested than a boring old silicone diode I wouldn't know where to start on how to construct.
Offline Dawn
« Reply #14 on: May 29, 2012, 10:55:08 pm »
I never heard of the manufacturer, but I wonder about the company's origin. Many years ago I read about a Soviet era MIG teardown that had been conveniently delivered by a defector. One of the surprising finds was the extensive use of what was referred to as miniature, low voltage, vaccum tubes that apparently were a very small, board mounted component. Resistance to EMP and ruggedness was cited at the most probable reason that they chose to use them in a relatively new 80's design. I wonder if these are the outgrowth of that technology?
Online tom66
  • Electron Fiddler, FPGA Hacker, Embedded Systems EE
« Reply #15 on: May 29, 2012, 11:18:42 pm »
Looks interesting, but the 460 GHz is only theoretical. If they can produce a practical device capable of even a tenth of that I will be impressed. I also wonder what power consumption is. With a typical vacuum tube it's pretty high because the filament must be kept warm all the time (constant stream of electrons); does this device require a constant stream of electrons to work?
Offline NiHaoMike
    • Facebook Page
« Reply #16 on: May 30, 2012, 02:22:10 am »
It uses field emission or something like that. I can see those nanoscale vacuum tubes being quite useful for RF and communications circuits.
BTW, tubes are still in common use. A lot of modern automobile dashboards are plasma displays. I'm guessing it has to do with plasma displays being far more tolerant of extreme temperatures, but LCDs are also very common in cars, so I'm not so sure on that. Even stranger is that while my new car (a 2011 Prius) uses plasma for the dashboard, the radio and A/C both use LCDs.
Offline T4P
  • Country: sg
    • T4P
« Reply #17 on: May 30, 2012, 03:47:59 am »
But those aren't tubes okay  :)
Online tom66
« Reply #18 on: May 30, 2012, 12:31:24 pm »
They're probably VFD displays, not plasma displays. VFD works on lower voltages (~10V); plasma displays require complex sustain/address waveforms and 60V/200V supplies.
« Reply #19 on: May 30, 2012, 03:28:32 pm »
VFD units are true vacuum tubes. Directly heated cathode, control grid in the electron flow and a segmented anode complete with electron activated phosphor as a display medium. I think you could use one as a triode with a little care in design.
Offline free_electron
    • SiliconValleyGarage
« Reply #20 on: May 30, 2012, 03:42:26 pm »
vacuum tubes (thermionic valves) sound really good ... especially when you hit them with a hammer and they go pling , kling , plong , klak.
Offline T4P
  • Country: sg
    • T4P
« Reply #21 on: May 30, 2012, 03:52:23 pm »
free_electron, small wonder why you are my god here, i entirely agree with you on every single level
Offline G7PSK
  • It is hot until proved not.
« Reply #22 on: May 30, 2012, 04:26:15 pm »
Not when you have stainless steel ones.
« Reply #23 on: May 30, 2012, 04:37:41 pm »
for steel ones : use bigger hammer
« Reply #24 on: May 30, 2012, 06:01:03 pm »
Ok, we will take the nice digital camera, and have them running in a high radiation area ( 100 G/H) along with a Vidicon and valve based camera. Which one will still be working in 5 minutes without any problems, and which one will still be running a year later.
Now guess why there are no nuclear clean-up robots.
