Author Topic: HELP, I need a transformer  (Read 7057 times)
Offline snipersquad100Topic starter
    • Electrinics
« on: December 05, 2013, 09:15:47 pm »
Can anyone please point me to a transformer for this ESR meter project.
Offline c4757p
  • adieu
Re: HELP, I need a transformer
« Reply #1 on: December 05, 2013, 09:20:31 pm »
The turns ratio is given because they intend you to wind it yourself.
    • Electrinics
« Reply #2 on: December 05, 2013, 09:24:19 pm »
Has it goto be in a bobbin?
Offline c4757p
  • adieu
« Reply #3 on: December 05, 2013, 09:26:54 pm »
Look up the core they have specified and try to find a similar one. (I don't have time to check ATM.) A small ferrite toroid would probably do, though 400 turns on a small toroid would be a bitch.
    • Electrinics
« Reply #4 on: December 05, 2013, 09:53:23 pm »
yeh, use the thinnest gauge wire I can find lol
Offline Bored@Work
« Reply #5 on: December 05, 2013, 09:54:38 pm »
Amidon cores are still available. A simple google of the product number will tell you.
Offline kg4arn
« Reply #6 on: December 05, 2013, 10:01:17 pm »
If you trust the design, I recommend using the exact core the designer has specified.
Switching cores requires that you have a good knowledge of what you are doing:  frequency range, core losses, saturation. . .
Offline Mr Smiley
« Reply #7 on: December 05, 2013, 10:10:25 pm »
I built one of those a while ago and found that a transformer from one of those CFL's was the same ratio  :-+
There using a transformer to ensure the impedance driving the capacitor is as low as possible.
Also it says 400:20, so would'nt any 20:1 transformer work  :-//
There is enough on this planet to sustain mans needs. There will never be enough on this planet to sustain mans greed.
    • Electrinics
« Reply #8 on: December 05, 2013, 10:19:31 pm »
Thanks smilly, i think the ratio has something to do with the current handling, not sure thou.
Offline Icarus
« Reply #9 on: December 05, 2013, 11:30:16 pm »
Maybe you can use E13/7/4. Its tiny and much more easier wind than a toroid.
I strongly recommend to use  bifiliar or trifilar winding. That'll reduce the skin effect.
Offline Bored@Work
« Reply #10 on: December 05, 2013, 11:34:41 pm »
There is only one problem with this theory. The core in question is an E core, not a toroid. Available for $2.50.
Offline Jay_Diddy_B
« Reply #11 on: December 05, 2013, 11:40:50 pm »
To the OP, snipersquad100,
Do you your mind set on building this ESR meter?
I have started two threads on ESR meters that do not need a transformer.
This is analog one similar to the one you looking at:
https://www.eevblog.com/forum/projects/5-transistor-esr-meter-design/msg171364/#msg171364
This one can be used with a DMM to get a digital readout:
https://www.eevblog.com/forum/projects/esr-meter-adapter-design-and-construction/msg341177/#msg341177
Regards,
Jay_Diddy_B
    • Electrinics
« Reply #12 on: December 06, 2013, 12:01:58 am »
The esr meter im interested is this one
He modified the schematic to work with arduino.
Im only building it for fun, I don't expect it to be highly accurate.
Offline at2marty
« Reply #13 on: December 20, 2013, 10:50:28 pm »
I'm currently working on one that is based off of the same video.  The modifications that I made were to make it "stand alone" rather than a shield that goes on an Arduino.  I also added in serial port capability for debugging and an ISP header for programming modifications.  I also re-wrote the source code in plain C.
The transformer that I selected is an audio transformer available from Radio Shack part number 273-1380.  I believe that it will work correctly, though it's a bit tall and will be close when I mount everything into the enclosure.
I just ordered some boards and should have them next week.  Once I do some testing to make sure that it works the way that I anticipate, I will gladly release the source code and the design files.  I used EagleCad for the schematic and board layout.
    • Electrinics
« Reply #14 on: December 26, 2013, 07:58:48 pm »
hi at2marty
Any luck with your esr meter?
    • Electrinics
« Reply #15 on: January 04, 2014, 12:35:20 pm »
Cant get any voltage out of c2, im using a 10uf cap. theres 2.5v going in but nothing going out to the transformer.
