Author Topic: Reverse engineering/reprogramming a cheap novelty audio device  (Read 594 times)
Offline HalcyonTopic starter
  • Global Moderator
See attached.
I was given one of these novelty "buttons" where each press has a different sound effect/phrase, seems like chosen at random. These are just mass produced single-sided boards with various different themes, so I'd imagine there would be a way to reprogram the chip with different audio.
I've buzzed out the pins, which seem to be:
Unknown IC
Pin 1 - Battery positive
Pin 2 - Speaker
Pin 3 - D1 (Unpopulated)
Pin 4 - Switch
Pin 5 - Speaker
Pin 6 - Battery negative
Pin 7 - N/C (?)
Pin 8 - D2 (Unpopulated)
D1
Pin 1 - To IC Pin 3
Pin 2 - To Battery positive
D2
Pin 1 - To IC Pin 8
Any ideas where I can start? I do have an EPROM reader/writer, but not sure if the above pinout resembles anything standard?
« Last Edit: April 22, 2024, 10:12:58 am by Halcyon »
Online tom66
Re: Reverse engineering/reprogramming a cheap novelty audio device
« Reply #1 on: April 22, 2024, 10:13:26 am »
I had always assumed these were based on OTP/eFuse ROMs and are not reprogrammable.  When we were looking at Nuvoton chips for audio the sales rep mentioned they have low cost audio options which omit the flash and are either mask ROM (for very high volume) or OTP (for mid-high volume).
Example: https://www.nuvoton.com/products/smart-home-audio/audio-speech-controllers/powerspeech-series/n588hp340-otp/
  • Global Moderator
« Reply #2 on: April 22, 2024, 10:17:35 am »
Ahh bugger!
Online tszaboo
« Reply #3 on: April 22, 2024, 10:26:02 am »
Ahh bugger!
I've even saw Jingle bells IC, which had 3 pins:
Power
GND
Jingle bells
The following users thanked this post: tom66
  • Global Moderator
« Reply #4 on: April 22, 2024, 10:28:36 am »
Well there goes that idea. Maybe I can rip the guts out of this one and replace it with a programmable module.
Offline Gyro
« Reply #5 on: April 22, 2024, 01:03:40 pm »
Replace the speaker with an LED (and maybe a series resistor) and you have a randomly flickering light. It's surprising how many random LEDs (tea lights) play pretty little oriental tunes when you shine them into a phototransistor. [Edit: a lot of the more modern ones produce some nasty white noise sounds].
« Last Edit: April 22, 2024, 01:07:07 pm by Gyro »
Best Regards, Chris
The following users thanked this post: SeanB, Exosia
