Author Topic: Rigol DS1052D hack (with LA)  (Read 13451 times)
Offline gnorf
« on: July 25, 2010, 09:23:22 pm »
Hello,
i read that ist possible to hack the DS1052E to a 100MHZ version.
Has anyone tried to hack the DS1052D Version (with LA)? Does it work too?
Does anyone know where to find an old 0.2.2 D-Version Firmware? I can only find the old E-Version firmware.
Thanks
Gnorf
Offline NiHaoMike
    • Facebook Page
Re: Rigol DS1052D hack (with LA)
« Reply #1 on: July 25, 2010, 09:57:06 pm »
You'll need the logic analyzer input board. Better to get a separate logic analyzer.
Offline gnorf
« Reply #2 on: July 26, 2010, 12:02:10 am »
My DSO ist the Rigol DS1052D with logicanalyzer hardware and want to use the 100MHz hack.
But i suppose i can not use the same firmware as used for de E-Version without Logicanalyzer.
Offline NiHaoMike
    • Facebook Page
« Reply #3 on: July 26, 2010, 01:00:59 am »
I believe there's a hardware hack that should work. It might actually be less risk than a firmware hack if you're comfortable with hardware rework.
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #4 on: July 26, 2010, 02:49:27 am »
you can software mod it actually... hackaday has a mention on it, and i tried to mod 1052E to 1102D, successfull! except, the DSO re-tune to some calibration thats not compatible to my E version (without the presence of LA module). i posted a thread in rcgroups.
It's extremely difficult to start life.. one features of nature.. physical laws are mathematical theory of great beauty... You may wonder Why? our knowledge shows that nature is so constructed. We simply have to accept it. One could describe the situation by saying that... (Paul Dirac)
Offline gnorf
« Reply #5 on: July 26, 2010, 12:06:28 pm »
Yes i found your thread...
Where did you find out that you must change the serial to DS1EA...
But i can not find any 0.2.2 SP2 D-version firmware only the old firmware for the E-version.
I can only find 0.2.4 version for D and E Versions and the 0.2.2 Version for the E-version.
« Last Edit: July 26, 2010, 12:45:27 pm by gnorf »
Offline Polossatik
« Reply #6 on: July 26, 2010, 12:51:16 pm »
the 2.02.02 SP2 D firmware is found in the zip file here
http://www.rcgroups.com/forums/attachment.php?attachmentid=2866736
or here
https://www.eevblog.com/forum/index.php?topic=553.msg10155#msg10155
I cannot help with your other questions, sorry
« Last Edit: July 26, 2010, 12:56:46 pm by polossatik »
Real Circuit design time in minutes= (2 + Nscopes) Testim + (40 +120 Kbrewski) Nfriends
Testim = estimated time in minutes Nscopes= number of oscilloscopes present Kbrewski = linear approx of the nonlinear beer effect Nfriends = number of circuit design friends present
  • Country: my
« Reply #7 on: July 26, 2010, 01:14:02 pm »
the DS1EA thing is by googling that popped out others 1102D serial number. so my conclusion IIRC. 1102D DS1EA, 1102E DS1EB, 1052D DS1EC, 1052E DS1ED, if i'm not mistaken, thats been quite a while since i did the homework... but be careful.
Offline gnorf
« Reply #8 on: August 07, 2010, 11:39:07 am »
Thanks...
tried too google but did not found any serials. I found a post at hackday with the serialchange for the D-Version DSO. My DSO has still the "old" 0.2.2 SP2 firmware and i must only change the serial and i got a new DS1102D DSO ;-)
  • Country: my
« Reply #9 on: August 07, 2010, 04:35:00 pm »
is your DSO vertical reading still ok? with your new 1102D?
Offline tlu
« Reply #10 on: October 02, 2012, 06:29:09 am »
Hi gnorf,
So you have managed to turn your DS1052D (model with LA) to DS1102D successfully I see. Can you help me in doing the same thing. I'm going to receive this unit soon.
Thanks,
Offline chapas
« Reply #11 on: February 04, 2014, 03:32:58 pm »
Can i update to version 4 and not loosing the hack?
Offline Sigmoid
« Reply #12 on: February 04, 2014, 03:59:59 pm »
Does the hardware hack still work with DS1052E's too? I vaguely remember having to desolder or replace a single resistor or something... Could someone link to it?
Offline allenpan
« Reply #13 on: March 25, 2017, 09:24:22 pm »
anyone about to update theirs DS1052D to DS1102D?
