Author Topic: RoHS legislation  (Read 876 times)
Offline jadew
RoHS legislation
« on: June 07, 2017, 12:25:26 am »
Hey guys,
I've been reading recently that electronic kits are exempt from RoHS conformity. Is this true? and if yes, where can I read about it?
I'm also curious about what constitutes a kit.
Thanks
Offline helius
Re: RoHS legislation
« Reply #1 on: June 07, 2017, 12:54:42 am »
A typical kit only contains components (which you can basically only buy in ROHS finish unless they are military spec), a printed circuit board (which you can have made in ENIG finish which is ROHS compliant), and instructions. Such a package would be compliant with ROHS; it is not an electronic product containing prohibited substances.
Offline jadew
« Reply #2 on: June 07, 2017, 01:14:36 am »
The problem is that one of the components doesn't have any RoHS compliance declarations in its datasheet. Also, I'd like to deliver the board assembled, except that a few cables won't be connected and there will be some screws to fasten too.
It's a plugin board for another product.
