I've added Kress to the poll list.
With age bearings and motor to wear, its vital to have spares as wear is expected, but they have to be far cheaper than buying a new tool.
I've dissected and owned Dremels for some time, and the plastic casing is fairly durable, but its not a precision device. The bearing mounts will wear with use, so it maybe good for limited precision work when new, but not as it ages, but it won't wear to the point its useless as a general purpose handheld grinder/drill.
FWIW, Dremel plastic housings in the 100, 200, 300 series have proven durability simply because its unchanged from a design of 20 years ago [called multipro, a rehashed 1980s mototool], using the same material. The original cases were metal back in the 1940s.
The newer tools, 4000 & 3000, still have to prove themselves, but the material looks to be of similar composite as the 100 series.
The 3000 is just a rehoused 300.
The 4000 is a "new" and in my eyes still unproven but the reviews on Amazon are very good, 3+ or less star review account for less than 5% of total responders, compared to 25% with Proxxon.
The electronics now include feedback control to maintain rotational speed, but how well it works under load has not been tested well, reviews suggest it works but rapidly overheats when overloaded. The overload protection is just a fuse, it blows, the unit dies, unlike the Kress design which allows feedback to the motor to reduce output until the overload is resolved. The Dremel electronics are not sealed, and also exposed to the inside housing, thus it can get fouled and shorted by metal debris. It is also larger, I cannot hold it like a pen as the Dremel 100 series, so they
sell an accessory so you can grip it better
I think the 4000 addresses complaints of users that fled to the Black and Decker RTX series tool. Basically, its used as an electric handheld die grinder. But unlike pneumatic die grinders, air keeps the unit cool and pushes out dirt, whereas the electric grinders suck in air, and thus suck in dust caused by grinding; it causes a lot of premature unit failures if its not protected from dust.
I personally do not use such tools for home repair routinely. It mainly in my bench to cut PCBs, casings, etc., in support of electronics. The small 100 series works better and is a tested design, and can do double duty for occasional home repairs.
we have a kress drill here at home the thing is more then 20 years old and the only problem of this the bearing and the shaft is resonating a bit, you cant make nice holes with this anymore, but apart from this its running fine with original brushes. it wasnt treated gently during its life.
as for the dremels these are intented for hobby/modelling work right? how can it contain any plastic parts for the internals? at those speeds just waiting to an accident...
for the does it different from the others or just a "new" look and a stronger motor?
