Author Topic: RS-555SH Motor  (Read 1934 times)
Offline vidarrTopic starter
  • Country: br
RS-555SH Motor
« on: February 01, 2022, 03:06:03 pm »
I have a RS-555SH Motor and downloaded the datasheet for it and see it comes in a number of voltages. The one I have is either 12V or 24V. How can I know which voltage it is?
Besides the one page datasheet, this is what I know:
It runs on 5V slow and weak and obviously not the right voltage.
12V decent speed and power.
24V fast and powerful.
This is going to be used for a fan, so the more power the better.
Thank You!
Offline Benta
Re: RS-555SH Motor
« Reply #1 on: February 01, 2022, 04:50:25 pm »
Spin the motor at a known RPM, eg, with an electric hand drill, and measure the voltage at the terminals.
Both types have an rpm of ~6400 at nominal voltage (12 or 24 V).
Example: If your hand drill has an RPM of 1500, the generated voltage will be either 1500/6400 x 12 V (~2.8 V) or 1500/6400 x 24 V (~5.6 V).
The following users thanked this post: vidarr
  • Country: br
Re: RS-555SH Motor
« Reply #2 on: February 01, 2022, 05:47:37 pm »
Brilliant! I have something that measures rpms. I can use a ESP32 to adjust (using PWM) the rpms.
This makes so much sense that I failed to see it.
Thanks so much!
Offline Benta
Re: RS-555SH Motor
« Reply #3 on: February 01, 2022, 08:01:19 pm »
I didn't mean drive the motor electrically I meant spin it mechanically with another motor, eg, power drill.
  • Country: br
Re: RS-555SH Motor
« Reply #4 on: February 02, 2022, 12:39:30 am »
Yeah, I understood that. I have another motor I am going to hook to the  RS-555SH Motor to drive it.
Thanks!
  • Country: br
Re: RS-555SH Motor
« Reply #5 on: February 08, 2022, 03:53:52 pm »
The result was this:
1800/6400 x 12 V = 3.375
1800/6400 x 24 V = 6.75
This seemed easier when I first thought about it. How exactly does this tell me if it is a 12v or 24v motor?
Thank You!
Offline Benta
Re: RS-555SH Motor
« Reply #6 on: February 08, 2022, 06:01:09 pm »
Is the voltage what you measured on the motor terminals?
  • Country: br
Re: RS-555SH Motor
« Reply #7 on: February 08, 2022, 06:33:51 pm »
Yes.
edit: BTW, my drill is almost exactly 1800. I hooked the drill to the motor and put my DMM to the terminals and then pulled the trigger. I did it a few times just to be sure. The voltages are solid, for sure numbers.
Thank You!
« Last Edit: February 08, 2022, 06:37:10 pm by vidarr »
Offline Benta
Re: RS-555SH Motor
« Reply #8 on: February 08, 2022, 06:57:40 pm »
Yes.
Thank You!
That can't be. If you spin the motor at 1800 rpm, you'll either get ~3.8 V for a 12 V motor or ~6.8 V for a 24 V motor. You can't get both.
What you've posted is the calculation, not the measurement.
Offline Kleinstein
Re: RS-555SH Motor
« Reply #9 on: February 08, 2022, 07:42:06 pm »
The DC motors run over quite some speed range. There is not a really fixed voltage, but one has to find your suitable compromise of power and expected life. Lets say you get the 12 V model. Than some 8 V may be good for a relativeyl long life use (e.g. FAN) and maybe 18 V OK for short time use where the life time is not impoartant and maybe 30 V for very short use with enough loading so it would not run too fast.
So likely the motor is a 24 V type. Normally half the rated votlage is already not so bad.
  • Country: br
Re: RS-555SH Motor
« Reply #10 on: February 08, 2022, 10:40:58 pm »
The only variable that is different in your equation is the RPMs of the drill "1800".
https://www.milwaukeetool.com/Products/Power-Tools/Drilling/Drill-Drivers/2606-20
So, I plugged that into your equation for both 12v and 24v to see the results:
Maybe the RPMs are not 1800 anymore? The drill is a few years old, but in good condition.
  • Country: br
Re: RS-555SH Motor
« Reply #11 on: February 08, 2022, 10:44:11 pm »
"So likely the motor is a 24 V type. Normally half the rated votlage is already not so bad."
Yeah, I just don't know the rated voltage. I have a 19v power supply, so I think I am going to go with that. But, I still want to understand that equation and how it works.
Thanks Guys!
