Another classic RS fuckup. I took a look at the table Simon indirectly refers to above and found this:
Now, I'm looking at the whole "
Instrumentation Amplifiers" table and there is
one part they are holding a "
Maximum Voltage Gain" parameter for, and that 'gain' is 0.172 dB (I suspect that it would be completely lost on the folks at RS that a gain of 0.172dB is obvious an error figure of some sort.*). Just one part, it's blank for all the others. The part, if you select on that field, is an AD8221, which actually has a maximum voltage gain of 1000, aka 60 dB, not 0.172 dB. Don't worry though, that's only wrong by a factor of 1000, what's that amongst friends?
What the fuck do they think they are doing?. They waste screen and database space to hold a selection parameter for one part and one part only, failing to populate it for the other 341 parts in that table. Then they even get the value stored there
completely wrong. To put it in terms that the folks at RS might understand, suspecting that electronics specific stuff confuses them, it's like having a box for 'colour' on a page where you're buying t-shirts and then filling it in with 'white' for one product which happens to be a black t-shirt and leaving the rest blank. All having that parameter selectable can do is make it
harder to find a suitable part. It doesn't merely fail to add value from their service, it actually takes it away!
* Perhaps this is why they do so badly at website design, they've go a metric somewhere that tells them how many customers they have gained and every time they make a website change the number goes up. Only they have failed to notice the minus sign at the front of it, 'sums' being hard and all that.
