What slows your computer down. You do. Every time you install a new program it will leave something in the start menu to say hey i'm here that all has to be loaded into ram every time you start, get something like ccleaner and go through the start up files and remove anything that you do not use regularly either by disable or remove, I normally disable at first then I will remove the item if it does not affect the computer or program adversely by being disabled.
