From pcbfx.com - don't use brother laser printers for toner transfer
B&W Laser Printers & Copiers are ideal, HOWEVER...
there is one laser printer manufacturer that has recently reformulated their toner specifically so that re-fusing is just not possible due to an epoxy-based formula to their toner powder mix. This IS new! Effectively, they have broken ranks with what has been the "standard" 9-component toner formulation used in the industry for all laser, LED and photo-static printers. This new formulation also requires very high heat (nearly 500ºF) to fuse the toner to paper which also prohibits successful transfers for our purposes. That's just too hot to work with. Currently, (thankfully) there is only one confirmed brand name and two that are only suspect at this time. These manufacturers and their models are identified at the bottom of the page and will alsays be updated if more manufacturers follow suit.
VERIFIED "No-Go" Printer: DO NOT USE!
BROTHER: All models manufactured after 2001 (all 4-digit model numbers)
HP-1102 & 1006 models (These have problems printing high-density toner)
ALL COLOR PRINTERS! Actually, a color laser printer/color copier can be made to work IF you can perform a particular trick. See TECH SUPPORT > Miscellaneous
SUSPECT Printers:
SHARP: AL-800
