Author Topic: Scale EEPROM?  (Read 6160 times)
Offline vlad777Topic starter
Scale EEPROM?
« on: December 22, 2013, 09:36:02 pm »
I disassembled two different (weight) scales from
two different manufacturers and apart from COB they
both contain 24C02 EEPROM.
What do you think is in these eeproms?
Many thanks.
Mind over matter. Pain over mind. Boss over pain.
Offline Len
Re: Scale EEPROM?
« Reply #1 on: December 22, 2013, 09:45:17 pm »
Calibration data?  :-/O
DIY Eurorack Synth: https://lenp.net/synth/
Offline mikeselectricstuff
    • Mike's Electric Stuff
Re: Scale EEPROM?
« Reply #2 on: December 22, 2013, 09:48:38 pm »
Calibration and probably also features - kg/pounds etc. the COB will be a mask rom, so having external ee allows the same one to be used for different models
Day Job: Mostly LEDs
Re: Scale EEPROM?
« Reply #3 on: December 22, 2013, 10:27:17 pm »
Could it be that the COB is uC and eeprom contains firmware?
(apart from calibration)
Offline tom66
Re: Scale EEPROM?
« Reply #4 on: December 22, 2013, 10:37:00 pm »
I would doubt it. Any firmware is basic enough to fit in mask memory. If there is any. A basic scale wouldn't need much more.
Re: Scale EEPROM?
« Reply #5 on: December 22, 2013, 10:48:20 pm »
What about calibration?
Is it programmed once or does the scale recal on it's own?
Re: Scale EEPROM?
« Reply #6 on: December 22, 2013, 11:02:18 pm »
it will be a factory cal to correct for cheap sensor  and electronics
Offline GreyWoolfe
  • NW0LF
Re: Scale EEPROM?
« Reply #7 on: December 22, 2013, 11:09:11 pm »
Back in New Jersey in the 80's when I worked for Nabisco as a salesman, I remember seeing the scales in he grocery stores with calibration stickers on them.  I seem to remember the scales had to checked for accuracy on a yearly basis.  Not sure though if the scales then were purely mechanical or had electronics in them.
Offline JoannaK
    • Diytao making blog
Re: Scale EEPROM?
« Reply #8 on: December 22, 2013, 11:31:05 pm »
I have even seen some cheapish chinese kitchen scales that are user re-calibrable. Just add 1KG atop and press some button combination mentioned in manual.
Re: Scale EEPROM?
« Reply #9 on: December 22, 2013, 11:41:55 pm »
Thanks,I didn't know that.
Sounds like a good idea.
Offline Zero999
  • 0999
Re: Scale EEPROM?
« Reply #10 on: December 23, 2013, 12:21:11 am »
I notice you've mentioned features. Do you mean it might be possible to hack it to a higher specification, like a Rigol 'scope?
Re: Scale EEPROM?
« Reply #11 on: December 23, 2013, 06:28:09 pm »
Typically the one chip solution is capable of working from 1kg to 300kg, depending on the load cell and mechanical base used around it. The ADC on there is typically a 14 bit unit, using digital smoothing and a lot of samples to get a stable reading. The eeprom will typically have a set of values for display type ( no of digits, decimal location, units and other annuciators), full scale resolution ( the load cell gives about the same raw digital reading from zero strain to max design strain), base count units ( the typical unit will do 5g intervals while the sensor result typically will be 2g5 or so but will drift a little), zero mass value (the unloaded mass of the weight platform and mechanical parts on the knife edges) and finally a scale value set ( one or more breakpoints) used to trim the conversion from digital ADC data to displayed data.
Typically you turn it on and level it, leave it to warm up for a hour or so then put it in cal mode ( can be a switch on the board, a button combo or a plug in dongle), zero it and then place a reference masspiece on and adjust the display to show the calibration mass. Some you do at multiple points to get the multipoint slope used to linearise the unit. I have one that requires a preset mass, so I have to use a combination of mass references to get the closest match, it is out by about 3mg then.
