ok, i took this the other way around, haha. First did the encoder but now hang at timing, still not sure how to pull this off.
my current code now goes as follows:
#include <EEPROM.h>
#include <LedControl.h>
#include <ezButton.h>
#include <TimeLib.h>
#include <RTClib.h>
#include <OneWire.h>
#include <DS1307RTC.h>
#define MAXIMCCLD 12 // output - CS/LOAD
#define MAXIMCCCLK 11 // output - CLOCK
#define MAXIMCCDATA 10 // output - DATA
#define DS1307_I2C_ADDRESS 0x68 // define the RTC I2C address
ezButton button(7); // create ezButton object that attach to pin 7;
LedControl MaximCC=LedControl(MAXIMCCDATA, MAXIMCCCLK, MAXIMCCLD, 1); // Define pins for Maxim 72xx and how many 72xx we use
int LED = 5;
int LED2 = 9;
volatile signed int counter_hour_start = EEPROM.read(2);
volatile signed int counter_minute_start = EEPROM.read(3);
volatile signed int counter_hour_end = EEPROM.read(4);
volatile signed int counter_minute_end = EEPROM.read(5);
// usually the rotary encoders three pins have the ground pin in the middle
enum PinAssignments {
encoderPinA = 2, // right
encoderPinB = 3, // left
// a counter for the dial
signed int lastReportedPos_hour_start = 1; // change management
signed int lastReportedPos_minute_start = 1; // change management
signed int lastReportedPos_hour_end = 1; // change management
signed int lastReportedPos_minute_end = 1; // change management
// interrupt service routine vars
boolean A_set = false;
boolean B_set = false;
int previousSecond = 0;
int tensofhours, singlehours, tensofminutes, singleminutes,tensofhours1, singlehours1, tensofminutes1, singleminutes1;
// SETUP
void setup() {
pinMode(LED, OUTPUT);
pinMode(LED2, OUTPUT);
pinMode(encoderPinA, INPUT);
pinMode(encoderPinB, INPUT);
// encoder pin on interrupt 0 (pin 2)
attachInterrupt(0, doEncoderA, CHANGE);
// encoder pin on interrupt 1 (pin 3)
attachInterrupt(1, doEncoderB, CHANGE);
MaximCC.shutdown(0,false);
MaximCC.setIntensity(0,15);
MaximCC.clearDisplay(0);
button.setDebounceTime(50); // set debounce time to 50 milliseconds
button.setCountMode(COUNT_FALLING);
setSyncProvider(RTC.get); // the function to get the time from the RTC
tensofhours = counter_hour_start / 10;
singlehours = counter_hour_start % 10;
tensofminutes = counter_minute_start / 10;
singleminutes = counter_minute_start % 10;
tensofhours1 = counter_hour_end / 10;
singlehours1 = counter_hour_end % 10;
tensofminutes1 = counter_minute_end / 10;
singleminutes1 = counter_minute_end % 10;
// LOOP
void loop() {
tasksEverySecond();
button.loop(); // MUST call the loop() function first
unsigned long count = button.getCount();
if (count>0) {
encoder_alarm();
// tasksEverySecond
void tasksEverySecond()
if (second() != previousSecond)
previousSecond = second();
displayRtcTime();
ledTest();
// ENCODER ALARM
void encoder_alarm(){
// reset button count when we cycle through all digit groups and set an alarm
if (count > 6) {
button.resetCount();
digitalWrite(LED, LOW);
//--------------------- HOURS alarm STARTS at ------------------------//
if (lastReportedPos_hour_start != counter_hour_start) {
if (counter_hour_start>23) {(counter_hour_start = 0);}
if (counter_hour_start<0) {(counter_hour_start = 23);}
lastReportedPos_hour_start = counter_hour_start;
EEPROM.update(2,counter_hour_start);
//--------------------- MINUTES alarm STARTS at ------------------------//
if (lastReportedPos_minute_start != counter_minute_start) {
if (counter_minute_start>59) {(counter_minute_start = 0);}
if (counter_minute_start<0) {(counter_minute_start = 59);}
lastReportedPos_minute_start = counter_minute_start;
EEPROM.update(3,counter_minute_start);
//--------------------- HOURS alarm ENDS at ------------------------//
if (lastReportedPos_hour_end != counter_hour_end) {
if (counter_hour_end>23) {(counter_hour_end = 0);}
if (counter_hour_end<0) {(counter_hour_end = 23);}
lastReportedPos_hour_end = counter_hour_end;
EEPROM.update(4,counter_hour_end);
//--------------------- MINUTES alarm ENDS at ------------------------//
if (lastReportedPos_minute_end != counter_minute_end) {
if (counter_minute_end>59) {(counter_minute_end = 0);}
if (counter_minute_end<0) {(counter_minute_end = 59);}
lastReportedPos_minute_end = counter_minute_end;
EEPROM.update(5,counter_minute_end);
//--------------------- 7 Segment display ------------------------//
if (count == 1 || count == 6) {
MaximCC.setChar(0,7,tensofhours,false);
MaximCC.setChar(0,6,singlehours,true);
MaximCC.setChar(0,5,tensofminutes,false);
MaximCC.setChar(0,4,singleminutes,true);
MaximCC.setChar(0,3,tensofhours1,false);
MaximCC.setChar(0,2,singlehours1,true);
MaximCC.setChar(0,1,tensofminutes1,false);
MaximCC.setChar(0,0,singleminutes1,true);
digitalWrite(LED, HIGH);
if (count == 2) {
} else if (count != 1 && count != 6){
MaximCC.setChar(0,6,singlehours,false);
if (count == 3) {
} else if (count != 1 && count != 6) {
MaximCC.setChar(0,4,singleminutes,false);
if (count == 4) {
MaximCC.setChar(0,2,singlehours1,false);
if (count == 5) {
MaximCC.setChar(0,0,singleminutes1,false);
// displayRtcTime
void displayRtcTime()
if (count == 0){
MaximCC.setChar(0, 7, (hour() / 10), false);
MaximCC.setChar(0, 6, (hour() % 10), false);
MaximCC.setChar(0, 5, '-', false);
MaximCC.setChar(0, 4, (minute() / 10), false);
MaximCC.setChar(0, 3, (minute() % 10), false);
MaximCC.setChar(0, 2, '-', false);
MaximCC.setChar(0, 1, (second() / 10), false);
MaximCC.setChar(0, 0, (second() % 10), false);
// ledTest
void ledTest(){
int midnight;
int powersaving;
int startTime = counter_hour_start * 100 + counter_minute_start;
int endTime = counter_hour_end * 100 + counter_minute_end;
int timeNow = hour() * 100 + minute();
if (endTime == 0000 && startTime != 0000){
endTime = 2359;
if (timeNow >= startTime && timeNow < endTime) {
powersaving = true;
} else {
powersaving = false;
if (powersaving == true){
digitalWrite(LED2, HIGH);
} else {
digitalWrite(LED2, LOW);
// Interrupt on A changing state
void doEncoderA() {
// Test transition, did things really change?
if ( digitalRead(encoderPinA) != A_set ) { // debounce once more
A_set = !A_set;
// adjust counter + if A leads B
if (( A_set && !B_set ) && (count == 2))
counter_hour_start += 1;
if (( A_set && !B_set ) && (count == 3))
counter_minute_start += 1;
if (( A_set && !B_set ) && (count == 4))
counter_hour_end += 1;
if (( A_set && !B_set ) && (count == 5))
counter_minute_end += 1;
// Interrupt on B changing state, same as A above
void doEncoderB() {
if ( digitalRead(encoderPinB) != B_set ) {
B_set = !B_set;
// adjust counter - 1 if B leads A
if (( B_set && !A_set ) && (count == 2))
counter_hour_start -= 1;
if (( B_set && !A_set ) && (count == 3))
counter_minute_start -= 1;
if (( B_set && !A_set ) && (count == 4))
counter_hour_end -= 1;
if (( B_set && !A_set ) && (count == 5))
counter_minute_end -= 1;
Many thanks,
Alek
