Poll
What's the meaning of "OL"?
Over Limit
29 (21.3%)
Open Line
2 (1.5%)
Over Load (Overload)
92 (67.6%)
Open Loop
4 (2.9%)
Depends on the measuring mode
9 (6.6%)
Total Members Voted: 136
Author Topic: Seriously, anyone know the story and meaning of "OL" on multimeters?  (Read 27213 times)
Offline TheAmmoniacalTopic starter
  • Country: no
It's used on every multimeter - yet everyone calls it something different. What is it?
Offline The Soulman
  • The sky is the limit!
Re: Seriously, anyone know the story and meaning of "OL" on multimeters?
« Reply #1 on: November 03, 2018, 11:16:54 am »
Imho its over limit, better would be out of range.
Offline VK3DRB
« Reply #2 on: November 03, 2018, 12:52:06 pm »
I remember a rather boastful electronic engineer at IBM seeing OL on fluke DMM, saying something like "OL means the meter is faulty".
OL is a defacto standard that works with seven segment displays quite nicely.
We use a lot of defacto standards without thinking about it. One defacto standard I hate is SMD tantalum caps having the stripe as positive, yet on electrolytic caps it in negative. Who ever devised the tantalum "standard" needs to be removed from the gene pool. It is illogical, stupid and dangerous. I think many of us have been caught out with that once.
The following users thanked this post: wilfred, David Aurora, edavid, SilverSolder, Johnny10, Jacon
Offline macboy
« Reply #3 on: November 03, 2018, 02:00:27 pm »
I can't believe overload is leading the poll. A meter is decidedly not overloaded with an open circuit on resistance mode. The measurement however is certainly over limit. Over limit works for all modes.
Offline xmo
« Reply #4 on: November 03, 2018, 03:03:02 pm »
macboy wrote: "I can't believe overload is leading the poll."
It's probably the leader because that's what it means.  At least according to what the manufacturers say in their manuals.
Keysight: "OL - Overload (the reading exceeds the display range)"
Fluke: "If the input signal is greater than the selected range can measure,the Meter displays overload"
The following users thanked this post: EPAIII, I wanted a rude username, teb
Offline Gyro
« Reply #5 on: November 03, 2018, 03:25:29 pm »
Datron:
- Overrange: "Is signified by a 1 being illuminated at the left of the normal display. 100% overrange permits a maximum display of 19999(9)."
- Overload: "Results in blanking of the display* when measured value exceeds 100% Overrange."
*(would be OL on other meters)
« Last Edit: November 03, 2018, 03:29:52 pm by Gyro »
Best Regards, Chris
  • Country: no
« Reply #6 on: November 03, 2018, 03:47:57 pm »
An overload indicator does not really make sense on modern multimeters, and really only makes sense in voltage or current mode (?).
I would guess the OL indication originates from back when voltmeters were resistive panel meters? An over-voltage condition would in this case cause it to overheat and potentially burn?
I've just looked at a few manuals, both Keysight and Fluke do say overload.
Offline Cyberdragon
« Reply #7 on: November 03, 2018, 06:47:31 pm »
Early digital bench meters have red overload lamps on them.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline Dubbie
My Keysight meter says Overload on the screen when open circuit on ohms mode
Offline pelule
  • What is business? It’s other people’s money
« Reply #9 on: November 03, 2018, 08:03:53 pm »
IMHO it's overload.
ADCs in the past have been single- ord dual-slope types. A integrator is charged by input voltage (and for dual-slpe again discharges by the reference voltage) The charge time is counted and gives the display value (count).
Thus exceeding the input range caused the integrator to be overcharged means overloaded.
/PeLuLe
You will learn something new every single day
Offline Mr. Scram
  • Display aficionado
« Reply #10 on: November 03, 2018, 08:09:54 pm »
It's obviously "Out of Luck".
The following users thanked this post: hans, SilverSolder, Gregg, Jeff eelcr, Kim Christensen, Dan123456
Offline wilfred
« Reply #11 on: November 04, 2018, 12:02:47 am »
Re SMD tantalum cap marking. Thanks for the warning. Only used through hole till now.
Offline Feynman
« Reply #12 on: November 04, 2018, 08:38:43 am »
For me its always been "over load". Most multimeter manuals describe "OL" with something like "Overload condition is detected", e.g. the manual of the Fluke 87V.
« Last Edit: November 04, 2018, 08:43:05 am by Feynman »
Offline BeBuLamar
« Reply #13 on: April 24, 2021, 11:31:17 am »
While it may not make sense it means "Over Load" because the DMM manufacturers said so. I just wonder which DMM was first to display "OL". Early DMM display a 1 for this.
Online tom66
« Reply #14 on: April 24, 2021, 01:39:18 pm »
I want to know why budget multimeters show a single "1" when in over-range.  If the concern is over logic complexity, I can understand not wanting to implement text characters, but a single or double hyphen would probably be more understandable.  So many times I've worked someone unfamiliar with multimeters through a problem and they've said things like, it reads "1 Volt"  and then only do you realise that they had it on the mV range and that's the overload indication.
Offline Neilm
« Reply #15 on: April 24, 2021, 06:01:29 pm »
Surely it means "Oh Lord" - given I most often see it on a continuity reading and I now have an open circuit to find in a bunch of wires
Two things are infinite: the universe and human stupidity; and I'm not sure about the the universe. - Albert Einstein
Tesla referral code https://ts.la/neil53539
The following users thanked this post: Black Phoenix, Dan123456
Offline Cyberdragon
« Reply #16 on: April 24, 2021, 06:24:12 pm »
Nixie (or other early digital display) multimeters have indicator lights for "Over Load". I'm assuming LCD DMMs in the 80s soon followed.
*BZZZZZZAAAAAP*
Offline bdunham7
« Reply #17 on: April 24, 2021, 06:26:22 pm »
Some of them spell it out for you.
The following users thanked this post: thm_w, edavid, I wanted a rude username, Dan123456
Offline rfclown
« Reply #18 on: April 24, 2021, 06:54:36 pm »
It isn't up for a vote. Read the manual.
Offline TimFox
« Reply #19 on: April 24, 2021, 07:58:42 pm »
I repeat the important bit mentioned above:  "OL" works nicely on 7-segment displays, but "OR" is perhaps harder to read.
Offline magic
« Reply #20 on: April 24, 2021, 09:16:44 pm »
The answer is "because ICL7106" ;)
Now, what Intersil was smoking, ask them...
Offline hans
« Reply #21 on: April 24, 2021, 09:20:29 pm »
Well, if you consider an Ohms measurement using a CC, then overload could be applied (somewhat reciprocally) that the open circuit voltage is being exceeded.
I agree over limit makes more sense, but my first intuition was that this terminology (among other generic terms) by chinglish translations.
Nonetheless, there are more conventions that we carry over by tradition rather than common sense. Otherwise the whole world would be using metric by now, and we certainly wouldn't have 0.635mm SOP packages that look like 0.65mm :horse:
Offline KE5FX
    • KE5FX.COM
« Reply #22 on: April 24, 2021, 09:28:03 pm »
But it's used even when 7-segment displays aren't.  In addition to the Fluke above, the mainstream HPAK DMMs also display "Overload" with open probes in the resistance mode.
It's especially weird because in continuity test mode, the default display is simply "OPEN."  Why didn't they do that for resistance as well?   :-//
Offline SpecialK
« Reply #23 on: April 24, 2021, 09:32:45 pm »
∞ infinity
Coming from an analogue multimeter to an autoranging DMM I only ever really saw the OL in ohms mode.  Luckily I've never measured voltage greater than the DMM could handle and I much less often measure current, usually I measure that from the bench power supply.
« Reply #24 on: April 24, 2021, 10:52:45 pm »
Na, can't be that. The seven segment abbreviation of that would be 5.0.0.L. and they just put 0.L.   :)
