I'm an Australian, and we moved on from 'Imperial' for a reason !
We used to have Pounds, Shillings & Pence, but changed in
1966 to
Dollars & Cents.
(The benefits are obviously beyond any explanations !!!!!!!! )
We
also changed our MEASUREMENT systems to
'Metric'. Why?......
(1) To conform with the rest of the 'Planet'....
(2) Because it's so simple, and makes total sense !!!!!!
It's
not an 'answer' to say that... "
Well that's just how we do it".
Hundreds of years ago... maybe.... but Today
I know it is ingrained in the American Psyche, and 'people' don't like 'Change', but...
I'm SURE if your
CountryFolk REALLY understood what it means, they may
object less !
Although I'm NOW in my mid 60's, I could
not IMAGINE giving a 'measurement' to a builder
or carpenter, of the likes of....
11', 6 + 13/16th's " (Inches....) ( the Farohs must laugh xx).
OK, let's explain this 'wierd' Metric garbage?.....
YES... it is 'DIFFERENT'.... but it has LOGIC throughout.
Obviously for starters it is a Decimal system. (Derr...). so 10mm = 1-Cm. And 100-Cm = 1-m. (About 3')
NO 13/16ths, or 11/32nds heaven forbid!!.... but now it gets interesting !!!!!!!!!!!!!!!!...
1 Kg = 1000 grams. 1 L (Litre/volume) = 1000 ML (Milli-Litres, obviously). .....
But 1 Litre of water, also weighs exactly 1 Kg !! (technically pure water, at 21-deg-C at sea level).
1 Cubic Metre of water, is exactly 1000 Litres!!, and is 1000 Kg's, being 1 metric Ton.
See how EVERYTHING ties together now !!!!!, being either weight, volume, dimensions......
What could possibly be simpler !!!!!
Mind you, even 'today', here in Australia, one can go into a hardware store like 'bunnings', and see
packets of screws/bolts like 3/16ths or 1/4 inch, to cater for the 'old folk' hahaha....
but the VAST majority is all METRIC now. Out tape-measures show both.....
Start changing folks !!!!!!!!!!
