We were tuning the equalizer at my church since we got a new sound system so we used a sine wave generator to try to find the resonant frequency of the room. Once we hit it, very interesting things happened. Stuff like wood strips on the walls started to vibrate and depending on where you walked you could feel it in your head, like some places were more intense than others. I imagine if we had actual kw worth of speakers pumping that for a long time things would start to break and it would probably be dangerous to the ears. The speaker we have is "rated" at 1000w (a fairly standard size for large PA systems) and the amp is higher, though we did not have it anywhere near it's max, and we all know those ratings are mostly BS anyway. But if you were to actually do that with several kw I'm pretty sure it could start to cause things to break, loosen up etc, maybe even take out windows.
