Author Topic: shielded banana cable with ground question  (Read 959 times)
Online Homer J SimpsonTopic starter
« on: August 15, 2023, 10:37:00 pm »
Question regarding dual banana jack cable that has ground provisions on both ends.
What is the gain and or benefit of a  banana cable that has the  shielding / grounding provision vs one that does not ?
What voltages / currents would the shielding and grounding make a difference and by how much ?
Usage example - connecting a power supply to a DMM.
[ Specified attachment is not available ]
« Last Edit: August 15, 2023, 10:41:00 pm by Homer J Simpson »
Offline Benta
Re: shielded banana cable with ground question
« Reply #1 on: August 15, 2023, 11:12:00 pm »
None at all. And how would you know that the prong spacing fits your instrument? There's no standard for that. Solution looking for a problem.
Offline sleemanj
  • Professional tightwad.
« Reply #2 on: August 16, 2023, 12:06:11 am »
There is a usual spacing between typical pairs of banana sockets, 19mm (0.75"), it's common enough that you could call it a defacto standard.
Eg measure the Com and Volts sockets on your multimeter, majority will be 19mm apart.
Offline David Aurora
« Reply #3 on: August 16, 2023, 01:31:44 am »
1. I can almost guarantee it's 19mm, basically every manufacturer in the world agrees on this (hence companies like Neutrik making dual banana connectors that meet that standard)
2. Benefit of these cables depends on what you're doing with them. This is exactly the kind of cable I would use with various bits of test gear on my shelves (e.g. balanced audio signal generator, attenuator boxes, assorted meters, etc)
Offline tooki
« Reply #4 on: August 16, 2023, 02:25:26 pm »
Why provide such an actively anti-helpful answer?
1. The fact that these exist indicate there is a use for them.
2. As others have said, 3/4” (~19mm) is the de-facto standard for banana jacks on most things. It’s what you find on test gear, speakers, etc.
The following users thanked this post: abeyer
Offline tooki
« Reply #5 on: August 16, 2023, 02:26:17 pm »
(Attachment Link)
A tiny bit of info can be found on that cable’s datasheet: https://www.pomonaelectronics.com/products/cables/coaxial-and-rf-cables/double-banana-plugs-shielded-balanced-line
Offline tszaboo
« Reply #6 on: August 16, 2023, 03:40:51 pm »
I was calibrating some power supplies a while ago, and the way the leads were connected definitely made a difference in the noise measurements. It's supposed to have max few mV of noise under full load. Having cables like this make the test setup foolproof, otherwise I had to swap cables for different tests.
Online abeyer
« Reply #7 on: August 17, 2023, 09:12:28 pm »
You can read about some cabling setups for measurement using the shield & guard terminals here:
Modern Precision Multimeter Measurements
(The details of "What voltages / currents would the shielding and grounding make a difference and by how much?" are left as an exercise for the reader  ;) )
Offline Tomorokoshi
« Reply #8 on: August 17, 2023, 09:23:17 pm »
Great. Now there's another cable I need to get.
