Author Topic: Show off some electronic art.  (Read 6964 times)
Offline ZeTeX
  • Country: il
  • When in doubt, add more flux.
« on: April 26, 2016, 05:18:39 pm »
One day I will make my own, but in the meanwhile, you can share here some electronic art like this:
Have fun  :)
The following users thanked this post: xrunner, Wolfram.Chrome
Offline Mark
Re: Show off some electronic art.
« Reply #1 on: April 26, 2016, 05:54:50 pm »
That is awesome, I'm going to make one of those!  :D
The following users thanked this post: ZeTeX
Offline klr5205
« Reply #2 on: April 26, 2016, 07:50:23 pm »
I made one a while back:
The CPU is an AMD Phenom II X4 945 from a previous home pc build.
(Edit: Sorry for the image size)
« Last Edit: April 26, 2016, 07:53:11 pm by klr5205 »
Offline rrinker
« Reply #3 on: April 26, 2016, 08:02:30 pm »
Do it right and his head could light up   :-DD :-DD
Offline klr5205
« Reply #4 on: April 26, 2016, 08:17:52 pm »
That actually occurred to me as I went ... I hid a black power resistor on his back, you can see one of the leads hidden behind the right-hand leg diode as you look at your screen.  (Actually I shouldn't have said that, because in the pic you wouldn't think it could work, judging by the orientation of the diodes  ::) )
It was meant to get power through its feet, with current flowing into the resistor shunting around the left leg, and returning through the right), however what I didn't account for was the fact that I apparently got one or both of the power rails when I soldered the feet down, so the legs are actually shorted together! I was just killing time on a Sunday so I didn't bother fixing it - its just a decoration after all - but now the only way to light him up is to power him through his arm as though he's being shocked!
Offline ajb
« Reply #5 on: April 26, 2016, 08:24:05 pm »
My wife's handiwork.  I think I might have another at home as well.
Offline alanb
« Reply #6 on: April 26, 2016, 08:32:54 pm »
Have a look at Mike'e Electricstuff
http://www.electricstuff.co.uk/electrofun.html
Offline MrSlack
« Reply #7 on: April 26, 2016, 09:16:53 pm »
Another classic. Not mine:
Offline botcrusher
« Reply #8 on: April 26, 2016, 09:34:07 pm »
9V are evil...
This is well known.
Offline lowimpedance
  • Watts in an ohm?
« Reply #9 on: April 27, 2016, 12:55:09 am »
And you were wondering "where did I put that TO126 Transistor?"  :D.
BTW I like it, and the others too. Good imagination and a little spare time for some fun. :)
Offline Carl_Smith
    • MegaMicroWatt - Carl Smith's Blog
« Reply #10 on: April 27, 2016, 02:39:42 am »
Not mine, but a recent favorite find.  High Voltage EPROM Man.
https://youtu.be/0TU8dggs96s
Offline ZeTeX
  • Country: il
« Reply #11 on: April 27, 2016, 10:38:43 am »
This is awesome!!
How did he got the HV inside the EPROM? just finding the right pins?
Online SeanB
« Reply #12 on: April 27, 2016, 12:00:30 pm »
He is applying it to power and a non ground pin, so it will arc over inside pretty well.
Offline bktemp
« Reply #13 on: April 27, 2016, 12:16:18 pm »
It looks like he burnt the bond wires, otherwise they would short the high voltage. Now the high voltage is arcing from the pins to the chip.
Offline Stonent
« Reply #14 on: April 27, 2016, 01:20:17 pm »
Wow, a CDIP dated 1997.
Offline rrinker
« Reply #15 on: April 27, 2016, 01:34:39 pm »
 I don't think that's what they mean by burning an EPROM.....
The following users thanked this post: Kilrah
Online SeanB
« Reply #16 on: April 27, 2016, 02:28:23 pm »
Thought I would show this, which I made when I was in training. Had another project, along with a power supply, but that sadly was stolen at some point.
Offline Carl_Smith
« Reply #17 on: April 28, 2016, 12:17:34 am »
This is awesome!!
I think it basically finds it's own way.  :)  As long as you are on opposite sides of the chip -- same side and it might arc across the edge of one side of the window.
I was going to post that DigiKey has 27C512 UV EPROMS in windowed ceramic package, but now I see that they are all listed as "non stock."  I wonder if any are still being manufactured.
Now you are giving me ideas.  :)
Offline rrinker
« Reply #18 on: April 28, 2016, 01:49:15 am »
 Hmm, I have one or two of some sort of windowed EPROM sitting around - no idea where I even got them or what sort of code might be on them, I should see if they are still readable before sacrificing them to high voltage arcs. Given that I've always kept them with an 8085 CPU and some support chips, if I had to guess it has the code to run whatever I pulled it all from - I think it was some sort of home brewed interface to a Teletype.
Offline Carl_Smith
« Reply #19 on: April 30, 2016, 09:32:26 pm »
Didn't think to post this before.  A couple years ago I made this little cube out of some worthless 28 pin PLCC chips.  I soldered 4 together in a square, made 6 squares, and built a cube.  Because I put the bottom of the chips out I couldn't solder the edges of the cube together, so they are actually glued to a cube of wood inside that I painted black first so it would show through any cracks.
