I can not really say which one I use most. Actually, each of my PSUs has its own work to do. Over the years I have most used this one, just because it is so very old.
It was my first PSU and I had build it myself - 35 years ago. I had no clue about design, no clue about electronics, there was no internet and no help far and wide. The only thing which was there, was an old transformer, a big 33000µF cap, a recitfier and some heatsinks.
So I looked for a schematic and scaled it to what I thought was sufficient. Since the only transistor I knew in that time was the 2n3055, I took a bunch of them and mounted them on the heatsinks I had, went for a case to 'Conrad', which was -I guess- so to say the german RadioShack. And so I tacked it all together.
BUT: It worked out of the box. It still works after 35 years, and you can short it at 25 amps. It stands like a rock with no thermal issues, for an hour as well as for a day or longer. If you switch it on, it sounds like a welding-transformer, and the noise intensifies under load.
I used it for cutting foam, charging car-batteries and everthing which neede a controlled voltage or current. I've no idea about ripple.
(and don't in fact want to know it).
I decided to make some photographs, and especially for eevblog I've taken it apart after 35 years to take some pictures for you.
Please, don't berate me for the "design". I was so proud of it and It did its job for more then three decades - and still does: I sometimes use it a a source for a 500W RC-airplane battery charger.
SInce then, I have bought other PSUs, which are of course much better. I will show the most important ones in another post.
The pictures show
1. Front view. Pots: voltage fine, voltage coarse, current
2. Rear view. Heatsinks for eight 2n3055
3. right side, heatsink for rectifier
4. Inside. 35 years in the dark ...
5. LM723, self-echted pcb, load-resistors
6. Transistor provisioning with load-resistors.
7. Front plate inside, volt meter, amp meter w. shunt.
