Author Topic: Show your Multimeter!  (Read 372685 times)
Offline bullet308
  • Jack of All Trades, Master of None Related to EE
Re: Show your Multimeter!
« Reply #175 on: September 16, 2012, 07:45:46 pm »
BTW, since the Vichy/Victor/Whatever 4070L was the topic of some discussion, I thought I would do a mini-teardown and review on it.
(Edit to add for archival/search purposes: it is actually made by HoldPeak in China:
http://www.holdpeak.com/0/Productshow.aspx?id=20063
(Thanks to bored@work  for the link :-)
As noted above, accuracy is not its strong suit (mine reads about 10% high on average), but its the cheapest (+/- $25) way to measure inductance and stretch your available ohms and capacitance bandwidth beyond what your typical DMM will do. As I had a pressing need to measure inductance and was about broke at that point, I gambled and gave it a shot. It turns out to be quite useful, but hardly a definitive example of type.
BTW, of note up front is that it is totally unfused and clearly marked on the front as "MAX 30v DC" on all inputs. After poking around inside, you had better believe that I have taken those limitations to heart. This meter is somewhere between a CAT-0-rating and a small hand grenade for use at anything much higher.
The rubberish/soft plastic armor peels off with some difficulty. Its so stiff and thin that it can hardly provide any shock resistance at all.
Two screws (including the threaded insert battery cover screw) and you are in. Eight more little screws and you have the main board out. Not much to it. The display is interesting in that the LCD is mounted in the front cover with two long flexible connectors at the top and bottom hooking it electrically to the main board.
Sandwiched in between is a remarkably simple and effective (and cheap) way of backlighting the LCD: a thin translucent layer of plastic to conduct light from a single white LED mounted to the side. My Extechs should have half as good a backlight, and better than most anything else this side of, what? Agilent? Fluke? Not sure even they work much better. Kudos for shipping a cheap meter with a good backlight.
It has three tiny trimpots on the board. Perhaps it could be more precisely calibrated on the ohms and capacitance ranges, at least within the limits of my Hameg bench DMMs, but as this is the only inductance meter I have , I cant do much with that measurement. Might try that later.
It apparently has some means of testing transistors built into the face as well, but I didn't test that, as I gather such things are typically about useless anyway.
Photos below. I hope this is of some use to anybody.
« Last Edit: September 16, 2012, 11:50:28 pm by bullet308 »
>>>BULLET>>>
Offline Bored@Work
« Reply #176 on: September 16, 2012, 09:03:42 pm »
Offline ablacon64
  • Country: br
« Reply #177 on: September 16, 2012, 11:18:14 pm »
Whatever = HoldPeak http://www.holdpeak.com/0/Productshow.aspx?id=20063
It's very beautiful in white, never seen a white meter before. :)
Offline T4P
  • Country: sg
    • T4P
« Reply #178 on: September 17, 2012, 12:07:09 am »
So you can showcase the scratches/dents you get on it  :P
Offline PA4TIM
« Reply #179 on: September 17, 2012, 08:19:18 am »
it is white ( kind a) and i love to have one but never seen one in real
Offline Amarbir[Lynx-India]
  • Country: in
  • Indian Dealer
    • Lynx-India - Visit Us For Not So Boring Electronic Instruments
« Reply #180 on: September 17, 2012, 08:50:58 am »
Well,
     i have no idea whats going on in this thread but as far as holdpeak goes the best they have is this
Three SMD Tweezer Multimeters -> http://www.holdpeak.com/0/Default.aspx
Regards
Amarbir Singh Dhillon [ Lynx-India ] , Chandigarh [ India ] - > www.lynxdealerstore.com , www.lynx-india.com
Indian Distributor For  [ Autoelectric , Sofitech , IDEOfy ,Peak Electronic Design [UK ] , Anatek And Creatronica ]
My Electronics Blog - > www.lynxchandigarh.com
Offline donald
« Reply #181 on: September 18, 2012, 07:41:44 am »
nothing  exciting , just normal use..
1)top left DMM - Dick Smith Q1429
2)top right hand - ST or T instrument model M-770
3)middle left  -  Fluke counter 1900A
4)middle Right - Fluke 8012A
5)Bottom - HP 3457A
sorry about focus , it was  having a bad day.. :)
« Last Edit: September 18, 2012, 08:49:24 am by donald »
Offline PA4TIM
« Reply #182 on: September 18, 2012, 08:21:33 am »
Your camara must be emotional upto tears while shooting the picture, I think I see an Agilent 3457 or so but it is rathher unfocussed
  • Country: in
  • Indian Dealer
« Reply #183 on: September 18, 2012, 08:28:50 am »
Donald ,
          Can You Name The Brands And Model numbers there .Specially that analog meter you have  .
Regards
  • Country: in
  • Indian Dealer
« Reply #184 on: September 21, 2012, 08:22:42 pm »
My Agilent u1242B
I've had too many to count I think.
No such thing as to many multimeters!
Sir ,
 Can you share more details of the same i am planning to buy one along with my protek 608
Regards
Offline steve30
    • Stephen Coates' Homepage
« Reply #185 on: September 24, 2012, 02:37:04 pm »
This just came in the post for me:
Got it off ebay for £20 inc postage. Battery holder was damaged, but I replaced it with an identical one. I already have a 1503 so am very familiar with the workings. Unfortunately, the case is really tatty and the handle was broken, but the sticker says it was last calibrated in 2008, and it seems to work nicely. It came complete with a set of good C batteries :).
Here it is measuring a 4.096V reference IC.
Inside:
  • Country: in
  • Indian Dealer
« Reply #186 on: September 24, 2012, 03:09:20 pm »
Well,
 Very nice how well this works is amazing .I also shop more lying there ,What are those  .Whats the total collection like .I Myself Wanted a amazing Digital One Also Myself with a retro look ,But there is a space issue issue currently
Regards
Offline Monkeh
« Reply #187 on: September 24, 2012, 03:15:27 pm »
Probably the one I bid on. The seller was driving the price up and selling it to himself for weeks. Apparently he gave up on ripping people off eventually!
Offline steve30
« Reply #188 on: September 24, 2012, 03:23:44 pm »
http://www.ebay.co.uk/itm/271059344157?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
That's the one I got.
I did bid on a few others which were going for not much more money, but got outbid.
  • Country: in
  • Indian Dealer
« Reply #189 on: September 24, 2012, 03:28:21 pm »
Got it off ebay for £20 inc postage. Battery holder was damaged, but I replaced it with an identical one. I already have a 1503 so am very familiar with the workings. Unfortunately, the case is really tatty and the handle was broken, but the sticker says it was last calibrated in 2008, and it seems to work nicely. It came complete with a set of good C batteries :) .
Well Steve ,
 I i Had To Get One benchtop DMM's that dave hates lol ,Then in that case i would go and buy one that has all the bells and whistles .like this when in the bench you have the best of the best .In my case i have lots of dmm's and voms and vtvm lined up for delivery to me  .i have started restoring the units i got and would be taking expert help from all
Regards
Offline Monkeh
« Reply #190 on: September 24, 2012, 03:35:18 pm »
Hm, fair enough, not the same one. Really annoys me when people do that, because it was blatently obvious that the guy was using multiple accounts to drive up the price, continually relisting under other accounts with slightly edited descriptions and photos taken in the same place from different angles. Nobody pays more than about £25-30 for these from what I can see, but I bid on the same one three times and got edged out literally at the 1s mark repeatedly, only to see it relisted under a new account a few days later.
Offline DeKemp
« Reply #191 on: October 23, 2012, 04:23:58 pm »
I upgraded form a 10$ meter to a Agilent U1241B, my first real meter.
Extremely happy with it, also got the bluetooth module for free with it.
Offline M0BSW
  • Left this site 2013, they will not delete it ????
« Reply #192 on: October 23, 2012, 04:39:31 pm »
*chuckle*
Seriously, I have two Fluke 77's that are probably 20 years old, work great, are still in cal, and I see no need to replace them.
(and yes, that's really one of my meters in the photo)
Ohhhh the nixie tube just love them, looking on e-bay for nixie tube gear wonderful
no one would or will tell me how to delete this account
  • Country: in
  • Indian Dealer
« Reply #193 on: October 23, 2012, 04:39:59 pm »
Well,
      Any Comments i am planning to buy the same .
Regards
Offline psycho0815
    • H-REG Blog
« Reply #194 on: October 23, 2012, 08:02:45 pm »
If you like, check out my blog (german):
http://h-reg.blogspot.de
Offline cloudscapes
« Reply #195 on: October 23, 2012, 11:33:48 pm »
uni-t ut60a
it's not amazing, but it's fine for my needs. I don't mind that the continuity isn't latching, as long as it's an instant crackle (and it is). autorange is a bit on the slow side, but overall I just don't feel like I need to hurry and buy a Fluke or anything.it does the job.
  • Country: in
  • Indian Dealer
« Reply #196 on: October 24, 2012, 06:06:05 am »
Regards
Offline itdontgo
    • My company website
« Reply #197 on: October 24, 2012, 06:55:56 am »
I have lots if these virtually in every room of my house and office.  They go in the bin when the battery runs down.  They're mainly used as a voltage checker more than a voltage measurer but that's all I need on my desk when I'm debugging code.
I have a good Mastech on the bench where it stays so I dont lose it.
Offline itdontgo
« Reply #198 on: October 24, 2012, 06:56:49 am »
They are made by Mastech btw.
Offline PA4TIM
« Reply #199 on: October 26, 2012, 05:25:14 pm »
So as a counterweight for all the far-east plastic here a meter that was build to last for ever.
The cabinet is wallnut with a copper shield inside. Accessoires are under the toplid. And the nicest thing is a illuminated scale. You can choose between 10M or " infintive" input resistance.
Its almost as new but I miss the original diode for AC. ( a glass one  like in a Hp410 or AVO CT-38, the kind that is nice in winter because they get comfy warm  :)
http://www.pa4tim.nl/?p=2915 more pictures
« Last Edit: October 26, 2012, 05:27:09 pm by PA4TIM »
