Author Topic: Show your Multimeter!  (Read 511639 times)
Offline shakalnokturn
Re: Show your Multimeter!
« Reply #1000 on: October 07, 2021, 10:39:22 pm »
That isn't Excavatoree's staircase though, let's hope his collection doesn't escalate too fast... May have to nickname as "Escalatoree"  :-X
If we can't stick to a single DMM or list them all and are showing only one manufacturer at a time, here's my biggest number for one manufacturer (even if there are a couple of AOIP they're from the same factory). Still photo is missing a couple DMM's then there's the clamp meters... Then there's the Fluke, GMC, Brymen handhelds and a few bench meters...
« Last Edit: October 07, 2021, 10:41:07 pm by shakalnokturn »
The following users thanked this post: minsik, Specmaster, Mortymore, Neomys Sapiens
Offline Neomys Sapiens
« Reply #1001 on: October 08, 2021, 01:48:16 am »
WHAT? Not one of those fancy ASYC or Mx3282 thingies? Thought so.  :-DD
« Reply #1002 on: October 08, 2021, 06:00:04 am »
I've owned a couple, one of the clamshell models, I didn't like the design that much and a later one with the sexy shape that I would have kept if it had had more counts.
The only real graphical DMM I've got my hands on so far is the Fluke 867B.
Offline armandine2
« Reply #1003 on: October 17, 2021, 12:24:54 pm »
https://www.aldi.co.uk/ferrex-digital-multimeter/p/806955502637600
Got a couple of these the other day - may be the second one may afford a young nephew some education, alongside say a breadboard and a few components (Ben Eater's clock module?).
Funny, the things you have the hardest time parting with are the things you need the least - Bob Dylan
Offline Excavatoree
« Reply #1004 on: November 12, 2021, 01:13:51 am »
Two more added to the collection after over 10 years of sitting in the "Junkyard" without LCDs.  I finally found some on the famous auction site that weren't too expensive.  I think they are Fluke Chinese factory seconds, or maybe they are pulls, but they are good enough for these cosmetically challenged meters.
I posted a link to the auction in the Buy/Sell/Wanted section.
The following users thanked this post: rsjsouza
« Reply #1005 on: November 13, 2021, 06:17:24 am »
My 3 amigos. The 8060A just joined 2 weeks ago.
Offline joeqsmith
« Reply #1006 on: November 20, 2021, 03:28:35 pm »
Sabtronics 2015A
Offline Excavatoree
« Reply #1007 on: November 20, 2021, 04:03:34 pm »
Someone else has a Sabtronics!  I thought I'd never see another one.
Offline joeqsmith
« Reply #1008 on: November 20, 2021, 08:45:45 pm »
Note the Caddock divider and custom designed fuse.
Offline David Hess
  • DavidH
« Reply #1009 on: November 22, 2021, 03:40:46 am »
I replaced the 1/16th amp fuse in my DM501 with a pair of 28 volt grain-of-wheat lamps in series as shown below.
Offline harrimansat
« Reply #1010 on: July 22, 2022, 08:28:00 pm »
« Last Edit: July 26, 2022, 07:25:37 pm by harrimansat »
Offline McCarthy
« Reply #1011 on: March 10, 2024, 05:10:49 am »
Why is this wonderful thread dead?!
I'm actually searching for a vintage meter but I can't find out the brand or model number. My dad use to own it and I always wanted the same. Here's what I remember:
- Made between 1984 and 1992
- Digital
- Very likely all yellow case, or at least the sides in yellow
- Likely from Fluke or Voltcraft, but not sure
- Grey rubber buttons
- I think there was no dial selector, only buttons
Here a rough drawing:
« Last Edit: March 10, 2024, 05:14:32 am by McCarthy »
« Reply #1012 on: March 10, 2024, 08:59:39 am »
- Digital
I can't think of that many hand held without dial.
Cold it be the the Metex M80 ? I think these were also rebranded as Monacor, not sure about Voltcraft.
The following users thanked this post: McCarthy
Offline McCarthy
« Reply #1013 on: March 10, 2024, 04:15:49 pm »
- Digital
HOLY SHIT. That's the meter! Thank you so much.
I searched Google images for hours every other year with all kinds of keywords but never saw this one.
I just searched for Voltcraft M80 and found the correct one. Time to keep an eye on eBay Germany!
Offline David Hess
  • DavidH
« Reply #1014 on: March 11, 2024, 12:17:13 am »
I resurrected my old Beckman Circuitmate DM25L with a new set of probes from Probemaster.
I miss manual ranging multimeters.  I would like to find a modern high resolution one.
Offline soldar
« Reply #1015 on: March 11, 2024, 01:21:33 am »
I have a couple Italian ICE 680R about 50 years old.
They use old 3V 2R10 battery which is difficult or impossible to find today.
Offline bitwelder
« Reply #1016 on: March 11, 2024, 08:06:16 am »
The ICE Supertester line had another very similar model, the 680G. The main difference IIRC was the 'range doubler' button on the 680R.
BTW, regarding the product name, "tester" is a common term used in Italy for multimeter.
The following users thanked this post: RAPo
Offline Calambres
    • Piso-Tones
« Reply #1017 on: March 11, 2024, 08:12:18 am »
Hi, old friend. It is not that difficult. I recently bought one from the fleabay for a friend's ICE 680-R. Also look here in our country:
https://www.reguerobaterias.es/p90035361_pila-2r10-3-voltios-para-multimetros-ice.html
or, even better, this CR123 to 2R10 adapter:
https://www.reguerobaterias.es/p90041957_adaptador-pila-2r10-mas-litio-cr123-energivm.html
Or, if you have access to a 3D printer:
https://www.thingiverse.com/thing:4803116
By the way, I also happen to have an ICE 680-R from nearly the same vintage as yours (circa 1978). Pretty good analog multimeter indeed!
Same here in Spain
« Last Edit: March 11, 2024, 08:24:02 am by Calambres »
Offline LMedu
« Reply #1018 on: March 11, 2024, 08:57:00 am »
Hi. I modified mine with this: https://es.aliexpress.com/item/1005005187823837.html   and I use CR123 batteries.
Offline rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #1019 on: March 11, 2024, 04:45:22 pm »
I used the same CR123 holder on mine and soldered wires to its terminals and to the board. It relieves the mechanical stress on the phenolic PCB, which on mine was becoming very warped
Offline soldar
« Reply #1020 on: March 11, 2024, 07:33:58 pm »
Oh, hi there.
I have those two meters stashed away in a drawer and with no intention of using them really. I keep them with an old slide rule, a 1970's Casio calculator and other things which i keep not because I need them or want them but because I am a sentimental old fart. And in the same drawer I found I have a brand new "heavy duty" battery for the ICE 680R, still in its blister packaging and so old it is probably totally dead by now. Probably about 20 years old.
I remember I had a problem with the ICE 680R in that the needle would not return to zero and it turned out the plastic front cover has some kind of antistatic treatment and I think I had cleaned the front with solvent and that had removed the antistatic treatment. I took it to the official repair place and they explained the issue and reapplied the antistatic treatment to the front and it worked well again. I seem to remember they did not charge me for that.
Those meters are strictly for the memories, not for actual use. I have other digital cheap meters for working around places and on the workbench I have a humongous digital meter which is most convenient to use because it just sits there on the shelf.  I need to build some wooden stands for small multimeters because they are a pain to read when I am holding probes in difficult places.
I have a very small digital meter which I find a bit confusing to use because it is auto-ranging to the max. It has two leads and no selection dial. You just connect the two leads somewhere and it will tell you if there is AC or DC voltage or resistance or .... It just decides what to measure. I am used to telling the meter what I want to measure.
Most of my electronic instruments are from about 1980. The CRT in my oscilloscope is so long the front sticks way out from the shelf.
As part of my collection of old memorabilia of no practical use I still keep a Clarivox CRT TV, circa 1980, which I assembled myself and it still works but I never use it. I have all the schematics and I connected a TDT decoder just for fun.
Yes, I am a nostalgic old fart.
Offline Calambres
    • Piso-Tones
« Reply #1021 on: March 12, 2024, 06:27:42 am »
Those meters are strictly for the memories, not for actual use...
Well, not really. I used to use it when aligning the IF in radios. DMMs are not up to the task. Now I've got a VTVM and the ICE 680-R is almost never seeing the light out of its drawer but there are things for which a good analog multimeter is still essential. The subtle movements of an analog needle are not easily obtainable with a DMM.
Of course my ICE 680-R rests in its drawer without a battery inside. No need either for its completely outdated ohm metering capabilities nor for a hideous battery, waiting there to leak and destroy the whole instrument... and I also have two or three of those 2R10 batteries in their original blisters from the heyday:
06/95 no less!  ;D
2066582-0
« Last Edit: March 12, 2024, 06:38:48 am by Calambres »
The following users thanked this post: BILLPOD
Offline SiliconWizard
« Reply #1022 on: March 12, 2024, 06:32:32 am »
I still have a Metrix MX43 in my collection. Despite its unassuming appearance, for a DMM that's over 30 years old and which had its last calibration a long time ago now, it's still working and still within specs. This thing just won't die.
Offline Calambres
    • Piso-Tones
« Reply #1023 on: March 12, 2024, 06:44:52 am »
ASMOF, I've got a couple of even older METRIX model 460:
... and even a much older Neuberger Voltmeter from the '30s or early '40s. A true relic!
« Last Edit: March 12, 2024, 06:46:39 am by Calambres »
The following users thanked this post: JoeRoy
Offline Edison
  • Country: cz
« Reply #1024 on: March 13, 2024, 07:55:59 am »
I restored the V/A meter, the glass and the old/new measuring cord are still missing in the photos.
Edit: 🤔Somehow the photos were being shuffled when saving
« Last Edit: March 13, 2024, 08:03:31 am by Edison »
Everything works as the weakest link in the chain
