Author Topic: some help needed ... mini SMT transistor called as BW ?  (Read 2203 times)
Offline Kiriakos-GRTopic starter
  • Country: gr
  • User is banned.
    • Honda AX-1 rebuild
« on: June 20, 2010, 05:52:00 pm »
I am trying to repair one PCB from an Olympus digital camera .
I have find the problem ...  but its tiny in size ...  ;D
Do you have any idea how to locate this part called as BW  transistor ?
1) camera & magnifier .
2) camera at full Macro .. with Macro lens ... still not powerful enough. (tiny target)
3) Complete PCB .
To see the pictures ... do 1 right click on them ...as soon it opens ... then left click ...view image ..
« Last Edit: June 20, 2010, 05:55:51 pm by Kiriakos-GR »
Offline tecman
Re: some help needed ... mini SMT transistor called as BW ?
« Reply #1 on: June 20, 2010, 09:15:26 pm »
There is a 50-50 chance that the transistor is not the only blown part.  Bigger question is what caused the transistor to go ?  Had to be something else, since the transistor looks like it saw some excessive dissipation.
Paul
  • Country: gr
  • User is banned.
« Reply #2 on: June 21, 2010, 12:57:14 am »
Paul this PCB its a working one ,  the most of it .
Its the main power supply of the digital camera ..
The current damage = does not light up the back light of the large " rear LCD screen ".
The LCD was tested with another PCB and it works ..
So the damage are limited mostly to this component , and if its more , it would be at the back light mini transformer .
But I need to find the transistor , so to get two or three of them, and test ..
alm
  • Guest
« Reply #3 on: June 21, 2010, 03:20:39 am »
At the SMD codebook (first character B), I find an NPN Philips BCW71HR in SOT-23R (reverse pin-out).
