(soft PVC cable.)
I'm looking for a "no memory" cable.
I didn’t say it was “soft”. I said it was “superbly soft”.
With that said, no cable has absolutely zero memory, and that includes silicone. (Interesting fact, some silicone is surprisingly deformable. I have some where you can take the stripped-off piece of insulation — so no copper inside — and if you bend it, it stays bent. Completely useless for my desired application as test lead wire.)
Most of today’s softest cables aren’t actually silicone. Other polymers can be just as soft or softer in practice. And of course the cable’s construction (conductor size and stranding, etc) make a HUGE difference in overall flexibility.
Anyway, since you have a camera, and thus it is a USB data stream, you can’t just use any cable, it needs to be USB cable specifically — or PCB made to USB impedance specs. You could, theoretically, make a flex PCB (the super thin orange ribbons) that would work. It would just be mechanically delicate.
Try the cheap dfrobot cable I suggested. It doesn’t have zero memory (since no cable does), but it is extremely soft.
