Author Topic: Thought this watch was cute...  (Read 4192 times)
Offline Holes FlowTopic starter
« on: August 09, 2018, 03:50:56 pm »
The following users thanked this post: SeanB, PointyOintment, GeorgeOfTheJungle, Gyro
Offline hexreader
Re: Thought this watch was cute...
« Reply #1 on: August 09, 2018, 03:59:41 pm »
Hey.... that really is cool  :D
At least for those of advanced years like me, who remember that electric meters looked exactly like that.
How much is it, and where can I buy one?
Online ebastler
« Reply #2 on: August 09, 2018, 06:24:09 pm »
Photoshop'ed?
Hopefully, otherwise that horizontal spinning disk would cut into your flesh pretty painfully...  :P
« Last Edit: August 09, 2018, 06:26:53 pm by ebastler »
Offline hexreader
« Reply #3 on: August 09, 2018, 06:43:41 pm »
Doh....
 :palm:
« Reply #4 on: August 09, 2018, 06:49:15 pm »
Can you make it stop or even run backwards?
Online ebastler
« Reply #5 on: August 09, 2018, 06:51:22 pm »
Nah, you can't even set the time on it because it is officially sealed.  :P
Offline NiHaoMike
    • Facebook Page
« Reply #6 on: August 09, 2018, 07:40:52 pm »
Photoshop'ed?
Could just be something made to look like a spinning disk.
Online ebastler
« Reply #7 on: August 09, 2018, 07:52:07 pm »
Photoshop'ed?
But without an actual disk which actually spins, what would be the point?!  ;)
Maybe it's just photographed from a well-chosen angle and the case is deeper than it looks...  ::)
Offline Cyberdragon
« Reply #8 on: August 10, 2018, 12:22:22 am »
Photoshop'ed?
could be a crescant shaped half wheel that gets kicked back and forth by the escapement.
*BZZZZZZAAAAAP*
Voltamort strikes again!
Offline Red Squirrel
« Reply #9 on: August 10, 2018, 02:09:03 am »
That's pretty cool.  I remember when all the meters were like that.  At one point the Hydro company sent out these devices you could clip on and it would measure your power usage by detecting every time the wheel makes a revolution.  It was fun going around the house turning stuff on/off to check.  Then a month later they started switching everyone to smart meters and those devices became obsolete.  Bad planing there. :P
Offline CatalinaWOW
« Reply #10 on: August 10, 2018, 03:12:03 pm »
It isn't a real power meter unless it has a real rotating pointer for each digit of the reading.
Online ebastler
« Reply #11 on: August 10, 2018, 03:39:20 pm »
Thank you for sharing that one! Never seen one of those.  8)
The scales go in alternating directions; so I think it is safe to assume that there is just a series of 10:1 gears behind the scale? Not easy to read, with most of the pointers being somewhere halfway between the scale marks for most of the time...
Offline CatalinaWOW
« Reply #12 on: August 10, 2018, 06:17:51 pm »
Easy to read.  Hard to read correctly.  Often the meter readers didn't graduate first in their class so each months reading could be kind of random.  But the errors do average out over time.
Offline james_s
« Reply #13 on: August 10, 2018, 07:01:09 pm »
That's what almost all USA power meters look like, even the smart meters are just that with an additional little module inside that reads an optical vane on the shaft with the disc. I've seen a few that are completely electronic with an LCD display but 95% of the meters in service look just like the picture.
It occurred to me I actually have an old meter, this is what the mechanism looks like inside with the glass dome removed. This one is made by GE and is probably about 10 years old.
Reading them is indeed tricky, it's something not many people really know how to do. These days it's more and more common for them to be read automatically by the "smart" module rather than having someone drive around and go manually read each one.
« Last Edit: August 10, 2018, 07:10:37 pm by james_s »
The following users thanked this post: ebastler
Offline metrologist
« Reply #14 on: August 10, 2018, 07:45:18 pm »
I used to watch my meter and compare my bill each month. I noticed it was off quite a lot, so I inquired and was told they don't actually read the meter every month, they statistically estimate usage and said it would all average out when they take the next reading. I wish I'd been able to keep my old meter. Cost me $1200 for a new one. I'm going to have to pay for a water meter too pretty soon (we don't have one...).
Offline station240
« Reply #15 on: August 11, 2018, 02:59:20 pm »
Sounds like an Apple product |O
Offline ciccio
  • Designing analog audio since 1977
    • Oberon Electrophysics
« Reply #16 on: August 11, 2018, 05:08:45 pm »
I'm sure it is  Photoshopped.
The panel is from an old Italian meter, and googling for the image I could find it only in an old Pinterest post, saying : "when your friends show you their latest Iwatch, this is the answer... they cannot buy it."
Best regards
Strenua Nos Exercet Inertia
I'm old enough, I don't repeat mistakes.
I always invent new ones
Offline NiHaoMike
    • Facebook Page
« Reply #17 on: August 11, 2018, 07:22:52 pm »
Reminds me of that microcontroller with a built in OLED that turns out to be photoshopped, then someone made them for real!
