Well if you're considering price, you could use the DAC of your microcontroller to connect to the ADC of a second 8 pin microcontroller where the second drives the stepper via some transistors. This is because you'd have 3 states: clockwise, stop, anticlockwise, which you can assign to Vcc, Vcc/2, GND respectively. If you only need to rotate one way, then it's even easier and just use a normal digital output.
If you don't want to use a microcontroller and only go one way, you can probably use a decoded counter IC like the 4022 or 4017 with the fifth output connected to the reset pin so it will only ever count through the first 4 outputs. The digital output of the microcontroller will go to the enable pin and the outputs of the counter IC will drive the stepper via transistors. If you want to go both ways, I don't think there is an IC with a counter, decoder, and bidirectionality all in one so you would need to convert the analog output from your microcontroller into two digital lines through some weird circuit design, pass that into your bidirectional binary counter, connect the output to a binary decoder, to the stepper motor via transistors and voila, you have the definition of unnecessary
And lastly, if you care about variable speed, I'm sure some 1 wire asynchronous transmission solution exists you can communicate to your second microcontroller (like Maxim's "1-wire"). If you're good at assembly, you can bit bang at a given transmission rate and make the second micro sync up with it based on the first pulse. Transmissions shouldn't be too long however as they will go out of sync. You can even make it two way by adding circuitry so both sides will only be pulling the line low to prevent a short circuit (like I2C but asynchronous). Add CRC verification in the transmission to make sure there is no miscommunication and the second micro can signal if the transmission has to be sent again. As this is done through software, both micros must have interrupts for other things off and they will be busy waiting focused on performing the transmission before they can run other code.
Or if you're really into analog, add to what I said in the second paragraph but make the source oscillator of the stepper motor a VCO with your analog output from your microcontroller basically be mathematically |out - Vref/2| * 2 into the VCO but done through analog circuitry. There will probably be linearity issues.
If you have to use PWM instead of analog output, well I hope you like 4th order sallen key low pass filters. Because the other solution is not pretty (I think it involves PLLs).
