I don't like the way the article tries to sell it.
• Lightning-proof and spark-free performance based on the nonconductive nature of fiber. This feature is critical in many industries that are subjected to severe outdoor conditions, such as cellular base stations and electrical power grids, or in applications that must avoid the potential for spark-ignited explosions, such as the monitoring of fuel gauges and cabin door interlocks in aircraft.
A damaged or cut 5W fibre is a massive ignition hazard. There's no way I'd put this in an aircraft or anywhere near flammables.
• Increased human safety based on the elimination of cable heating, which is prevalent in copper-based systems. This is of particular benefit in applications such as magnetic resonance imaging, in which heating can create a serious risk of burns if the cabling comes in contact with the patient.
Fixing one hazard and creating another is not a good solution.
If you ever use anything like this it will either need:
(1) Some really clever fail-safe method of detecting light leaks. Optical leak detection lanes in the fibre jackets, reflectance monitoring, etc.
(2) Really low power levels. In which case you skip this style of high-power product and even the electrical conversion step by using reflectance-style passive sensors.
This is an already existing technology. One method: small LCD changes the amount of light being reflected back down the fibre, its opacity gets modulated by a local sensor (big thermocouples, etc).
