Hello My friend works for a small Street-lighting company in the North of UK.
He says that whilst working there he is condemned to never being able to use his SMPS design skills…is this likely to be true?
His company buy offline LED drivers as follows from eg Philips………………
http://www.docs.lighting.philips.com/en_gb/oem/download/xitanium-led-drivers-outdoor/Xitanium_150W_0.1-1.05A_Prog_GL-F_sXt_929000709003.pdf…they then fit these offtheshelf LED drivers into the lamp head, and voila….sell the streetlight.
Electrolytic capacitorsAll the available offtheshelf , offline, isolated LED drivers for streetlighting , contain electrolytic capacitors. This is because this is the only practical way of preventing serious levels of 100Hz flicker in the light of the LED streetlight. (film capacitors could be used to help prevent high levels of 100Hz flicker, but it would be way too expensive to replace electrolytics with film capacitors) Serious 100Hz flicker is not illegal for streetlighting (neither is it in any way harmful)…however, high levels of 100Hz flicker are illegal in Europe for indoor lighting…and the fact that this is the case, is used as a scaremongering tactic to deter European customers from even accepting high levels of 100Hz flicker in streetlighting.
Electrolytic capacitor free streetlight driverAnyway….he was told by his boss that he would be tasked with designing Electrolytic capacitor free offline streetlight drivers using SMPS……(the boss even managed to get a business development grant in order to investigate this)……the thing is, the 100Hz flicker problem virtually certainly means that this project is a hopeless loss maker……..seriously 100Hz flickering streetlights are never going to sell …at least not anywhere in Europe. (there’s no sane reason for this, but its just the way things are and will stay.)
Not only that, but a reasonably priced, isolated offline electrolytic-capacitor-free streetlight driver would likely use a single_stage_Flyback SMPS……..Due to being a Flyback, (and the high RMS current in it since it appears straight after the unsmoothed mains bridge output) such a converter would likely be less efficient than an offline led driver comprising a Boost PFC followed by say a 2-transistor-forward converter. (admittedly the latter would have an electrolytic capacitor bank after the Boost PFC stage……but it would likely be more efficient than a single_stage_Flyback of the same power level….so its another nail in the coffin of the electrolytic-capacitor-free, isolated LED streetlight driver…(OK there are ways of doing it more efficiently, but these are too expensive)
As such, my friend believes that this electrolytic-capacitor-free streetlight driver task that he has been tasked with is a "no-hoper"…
as soon as the Business development fund money has run out….then so will the task just die off.
Compete with the major electronics corporationsThe other alternative is to actually design an offline, isolated LED streetlight driver with electrolytic capacitors and try and compete with the major electronics corporations such as Philips, Tridonic, Osram, Samsung etc etc…………….
This is surely hopeless…
..there’s no way a small company would be able to get the kind of component cost-downs that the big electronics corporations can. Not only that, but the mainland European electronics corporations, have benefit-clique style relations with the European semiconductor fabrication plants, so they can get components far cheaper than a UK company would be able to. (there are no major semiconductor fabrication plants in the UK, neither are there any significant UK owned electronics component makers).
So do you believe it is true?….can a small UK company never be able to design its own offline, isolated, SMPS based LED streetlight drivers as part of competing in the streetlight sales arena?
The company are deterring him from trying to leave by saying that he will be able to design offline streetlight drivers at the company. In truth, he believes that this is never going to be the case…the streetlight market is one of huge volumes, and the huge European electronics corporations have it totally wrapped up.
Chinese importsMy Friend believes that the real reason that they want him to stay…… is to do bits of general software and general analog interface circuitry…something that in truth, they would be better off getting a different engineer for. Also, the company buys in lots of Chinese made SMPS based lighting, and middle-mans it onward, and it is deemed that it kind of helps to support this business if you have an SMPS engineer in-house…(every now and then an imported Chinese SMPS may fail, and it is deemed to help if you have an engineer in house who can make out some kind of technical-sounding report on what may have caused the failure)…..in truth, this job hardly needs anyone with SMPS design skills…since the company don’t even have the schematics of the Chines import products.
Another point, is that when UK leaves the EU…the UK government are likely to impose high tariffs on these Chinese imports, and so this may well close down a lot of small UK owned lighting companys……..because the Chinese import business is said to be the major profit making activity of small UK owned lighting companies.
In the UK, there are actually a number of “electronics design” companys which are no more than “puppet companys”…pretending to be what they are, when in fact, the “real” company is in China…and the Chinese simply use the” UK company” as a vehicle through which they can import their Chinese products into the UK and the EU without paying the import tariff….the UK “puppet company” is usually a very convincing disguise…they are staffed with British “engineers” and sales staff etc etc…you would just think it was a totally British company….you would never realise that everything was being designed in China, and then transferred across to UK. The Chinese secretly direct all operations in the UK “puppet company”. I think the UK government will hunt down these puppets after Brexit, and impose huge tariffs on them…closing them down.
So do you believe it is true?….can a small company never be able to design its own offline, isolated LED streetlight drivers as part of competing in the streetlight sales arena?
