Author Topic: OLED  (Read 1668 times)
Offline Jane
OLED
« on: June 14, 2016, 07:30:32 pm »
Can anyone advise where I can  buy OLED with a specification like this
http://www.visionox.com/en/color_js.aspx?cid=219
I would need about 10 pcs
Thanks
Offline MLXXXp
Offline Jane
Re: OLED
« Reply #2 on: June 15, 2016, 10:15:39 am »
Thanks for the link. But it is a different manufacturer. Do you think that it will work and the IC drivers are the same?
Offline MarkF
Re: OLED
« Reply #3 on: June 15, 2016, 11:06:22 am »
I have a breakout board from Adafruit with it's big brother (the SSD1351).  It's easy to program (I'm using PIC microcontrollers).  I wrote my own driver in C within a week.  The most difficult part is creating a font.
Offline MLXXXp
Re: OLED
« Reply #4 on: June 15, 2016, 04:16:13 pm »
You asked for a part that matched the specifications, not the exact part made by a specific manufacturer.
I couldn't find the driver IC used for the part that you linked to. If it uses the SSD1331 then the drivers should work. I also couldn't find the connector pinout for your part. The number of pins and the pinout  may be different between the two.
Offline MarkF
Re: OLED
« Reply #5 on: June 16, 2016, 12:55:11 am »
Attached are the specifications for the SSD1331 with its command set.  Also attached the schematic of Adafruit's breakout board.
Edit:  Updated schematic.
« Last Edit: June 16, 2016, 02:57:46 am by MarkF »
