Thanks to post focusing to 10's improved performance rather than its UI, its something I'd look forward too in my next hardware purchase, as I had with previous Windows iterations. From here and elsewhere I see an executive summary as:
Performance no less than 7 in terms of execution speed across all apps, and better in others. Many websites with benchmark reports.
Faster boot times from OFF.
Much improved security: sandboxing, authentication etc.,
Requires same hardware footprint as 7
Can run Truecrypt only with MBR not GPT on drives and BIOS not UEFI, which increases cold boot time
With many legacy applications on my 7 box, many from defunct or custom vendors, should I fix what isn't broken? A compelling answer would be if periodic security upgrades finally ended for 7. In some of our old XP boxes, we disconnect it from the Internet and continue to use them for data acquisition.
Since my first post, I've opted to remove the upgrade icon on my 7 box as per Microsoft's instructions. When I logged on again, it reappeared; I've repeated this cycle 2x, and now the icon stays on permanently. I know I can delve into the system and finally remove it, but I followed the exact instructions posted by Microsoft so why is the icon still there ?
We have boxes using Vista,7, XP, both 32 and 64 bit, with ne'er issues as we remove as much of its unnecessary functionality [ e.g. Aero] so they all look and function as close to XP as we can.
In December 2014, I returned from a trip to the Pacific onboard a plane with wifi. For 15 minutes, the wifi was opened free as a trial, then it was pay. I used my Nexus 7 and Droid phone to log on and check it out, booted, recognized, and surfed in less than 1 minute, albeit it was jerky and slow, not worth $35 for the entire trip.
Beside me was a passenger using a Surface; it was beautifully designed, and had those multiwindow icons that popped up everywhere. As the wifi appeared she pressed buttons here and there, it interacted with her, it showed her some pretty waiting icons, some app notifications awaiting wifi to update itself but 15 minutes later, she still was not connected and the trial was over.
https://tomssl.com/2015/01/15/fix-the-wifi-on-your-surface-pro-3/After watching her, I took out my old Netbook Win7 Starter edition, cold booted and logged on, and while the trial was over I reached the page for paying in 5 minutes.
