a bit off topic but ... A simple trick to make the texts on chips readable ... lick your finger (make it wet) and put the finger over the chips.
back on topic ... I made quite good pictures with my Canon A580 on a tiny tripod, a 2-3 second timer and macro mode and optional, if there's no good light, flash
Here's an example of such an image, an old Trendnet 5 port ethernet router with usb printer server (picture opened from backups, crop and save to 80% quality jpeg, you can check exif information if you don't believe me).. this one was done without tripod, with a bit of care so that the flash won't reflect on heatsink
I could resize it to 1920x something and everything would still be quite readable, and the image size would be probably less than 200-250 KB
