Author Topic: Purpose of copper "lines" coming from PCB vias?  (Read 992 times)
Offline kalelTopic starter
« on: December 02, 2017, 10:16:28 pm »
I've seen something like this on another board before, and this time on a cheap LED light PCB.
What is the purpose of these?
The images were taken quickly, some are blurred.
Offline T3sl4co1l
    • Seven Transistor Labs
Re: Purpose of copper "lines" coming from PCB vias?
« Reply #1 on: December 03, 2017, 06:54:41 am »
Thieving patterns for wave soldering?
Not so much "thieving" itself, but providing paths for solder to wick away rather than stay globbed on the pad.  There's probably a better term.
Seven Transistor Labs, LLC
The following users thanked this post: kalel
Offline TerraHertz
    • It's not really a Blog
« Reply #2 on: December 03, 2017, 09:18:23 pm »
They are not 'copper lines', but linear openings in the solder mask. You can faintly make out the actual copper track and pad areas in your photos, and they are much larger than the pads.
The purpose of these copper exposures, as mentioned, is to reduce the amount of solder that stays on the pad during wave soldering. Thus saving the manufacturer some money - significant over thousands of boards.
« Reply #3 on: December 03, 2017, 10:00:43 pm »
I did not know what to call them. Thanks for the explanation.
