their biggest problem is due to the modules not being as water tight as they should. This is a not a major obstacle to overcome but with their customer withdrawing they have a cash flow problem.
I would say the biggest problem is that it just doesn't make sense. Dave explained this multiple times in his videos. The cost is too high, and efficiency too low, compared to for example roof mounted solar cells.
The error in Dave's reasoning is the assumption that there is enough roof space to begin with all around the world. Since this assumption is false (for various reasons) it is good to look for alternative places to put solar panels. For example: in the NL there is not enough roof space available to produce a significant amount of electricity (not because I think so; this has been determined by a study using a tool to determine what kind of output to expect from a roof and simply adding all the roofs available in the NL). Not saying solar roadways are the solution but I'm simply not seeing a definitive answer that it is a no go. So far getting a good enough road surface seems problematic. Until that is hashed out nobody can say solar roadways are financially viable or not. There is not enough evidence to support either standpoint. It is simple as that.
BTW building roofs over ways has been debated already. In short: If it where such a good idea we'd start seeing them by now but in reality putting a roof over a road opens a whole can of worms making it incredibly expensive. More expensive compared to integrating the solar panels in the road surface.
Roofs don't have to be "all around the world".
In Australia, for instance, the "urban sprawl" so denigrated by town planners & the like, offers a plenitude of roofs just "sitting there".
Individual rooftop solar panels are already viable in this country, & if supplemented by direct solar hot water systems, offer those (many) people with suburban dwellings a significant saving in electricity costs.
If you have an older style "1/4 acre" or "1/5 acre" block, clothes drying can use a rotary clothesline saving directly on power otherwise devoured by energy hungry clothes dryers.
The large houses on relatively tiny blocks currently being pushed here limit the space for that, but even so, use of a clothes dryer can be avoided for much of the year, using small "stowaway" clotheslines.
Apartment living, which is pushed by many well meaning folk as being more "environmentally friendly" is incredibly energy intensive.
Cooking, heating, cooling, hot water & clothes drying (unless we go the Hong Kong route, with lines strung building to building ), all require electricity from the grid.
The new apartment buildings touted as "luxury living", are very large, & do not have enough roof area to begin to install sufficient solar panels to do the job.
Industrially, things are variable------ "Victoria Bitter" beer is currently advertised as produced in an entirely solar powered facility.
BP have been pushing the "solar powered" story for ironically, their petrol stations, where supposedly, the pumps, lighting, refrigeration, airconditioning, etc are all solar powered, even in the city.
This has been the case for "roadhouses" belonging to all the fuel companies out beyond grid coverage for some years.
Even when a huge EHT line passes a remote roadhouse, it isn't viable to supply it direct, but most such are many km from any incarnation of the grid.
Towns not fed by the grid also often use solar, windfarms, or a mixture of both, with a disel or gas backup.
Once in the cities, the grids are mostly dominated by fossil fuel generation, so lessening the load on such is important to minimise their carbon contribution.
