"And how would a solar pavement not become equally covered in snow? You seem to be failing at even the most rudimentary logic, sorry."
So we have established that that wonderful black asphalt covered in snow isn't that wonderful at melting snow.
Now, we can refocus you at understanding how snowplow may not be necessary with our solar walkway: what energy source do you think the solar walkwaybis connected to? Would it be too difficult to envision utilizing that energy source to melt snow fall on the solar walk way?
Think about it for a second I think the answer will come to you.
It came to us, but we are equipped with basic common sense.
You need a lot of energy to melt snow. I saw 300W/m2 figures, to melt 4cm of snow per hour (if the temperature is 0 degrees). After you melted, you got some that awful efficiency system, which is even handicapped becuase it is winter, it was about 7% peak of the nominal capacity (today, here) for something like 10W for the same size, for 8 hours. Even with best calculation, you need days to melt 4 cm snow. If the temperature is below 0 degrees, the numbers are even worse.
And you actually need to clean the road, because of cars.
And snow has to be melted evenly, across the entire size, otherwise you loose your efficiency even more.
