Author Topic: Solar panel testing by energizing them  (Read 1175 times)
Offline andyB2022Topic starter
« on: August 10, 2022, 04:54:53 pm »
Hi! While I was roaming on YTI've found a guy who showed a pretty "clever" method of how we can test a solar panel that appears to be with the naked eye in very good condition, but...under an IR camera the whole story is different.
Video link:
The following users thanked this post: tom66, thm_w, evb149, ANTALIFE
Offline thm_w
  • Non-expert
Re: Solar panel testing by energizing them
« Reply #1 on: August 10, 2022, 10:09:47 pm »
Very cool.
Now to look around and see if there are any cameras that can be easily modified https://www.extremetech.com/electronics/144388-how-to-turn-your-dslr-into-a-full-spectrum-super-camera
The following users thanked this post: andyB2022
« Reply #2 on: August 11, 2022, 06:55:07 am »
Or just use a regular camera and buy an IR cutoff filter as the guy in the video above did.
Looks like there are people out there that test those solar panels even in the field, check the photo below.
This might be a great video ideea for Dave, I guess  :)
Offline Silicium81
    • Technical forum
« Reply #3 on: August 11, 2022, 07:10:09 pm »
See here, I tested defective solar panels with this method. (in french)
A filter placed in front of the lens cannot work, the internal filter must be removed.
https://vae-tech.forumactif.org/t229-tester-un-panneau-photovoltaique-en-electroluminescence#2108
Electronic engineer with a passion for mechanics
Offline james_s
« Reply #4 on: August 11, 2022, 09:08:30 pm »
Many inexpensive security cameras have a night mode that uses a solenoid to move the filter out of the way, in many of these you can also turn off the IR illuminator, so no modification needed.
The following users thanked this post: thm_w, andyB2022
