It seems to be the month for me to try and repair electronic equipment. This is my second one I have asked about in as many weeks. (Where is the best place to post this question for the best help from people? )
I have a Sunlover Solar Solar Pool Heater controller; "Computer Solar Control Model CSC-V3" the unit was purchased in 1999 so its 21 years old.
When, hail came through our area the other week (Melbourne, Australia) the roof sensor thermister cable took a direct hit from a hail stone about 30mm from the sensor and was sheared right through. (Not surprising for a 20 year old UV damaged cable). The cable is too old and brittle and the break too close to the sensor for me to do soldering and repair the cable and have it be reliable, so I need to arrange a replacement sensor.
The company that originally made it, Sunlover Solar, appears to have been rebranded to Sunlover Heating. They have been contacted but have no interest in helping us out with information and want us to buy a new unit which can be upwards of $500. I suspect the only relation they have to the original Sunlover Solar is the name. They probably don't even have the IP (intellectual property) to the original CSC-V3.
I don't want to have to spend $500 simple For want of knowing the correct 5cent component we need to use. The unit itself is otherwise reliable and works efficiently and effectively for what we need it to do. (well, it did before the sensor cable was broken)
I purchased a new cable labeled "Sensor - Roof Analog Suit Ascon Controller TS11PP" made by Dontek Electronics that the pool shop I brought it from claimed to be the type of sensor people use on these Sunlover controllers when the need to replace the sensor. HOWEVER when I plugged it in I get a reading of 01 on the unit. I have checked the terminals and ensured the new cable is properly seated and tight and making contact with the unit (as best I can) When the roof sensor cable is removed the unit readout reads 99 for the roof sensor.
We have no circuit diagrams, no technical information, nothing except the old sensor the new sensor and a bunch of photos of the inside of the unit. (And the unit itself, of course)
I was able to test the original damaged sensor and appears that it reads 25.4Kohms at about 23degrees c and when I heat it up the resistance gets lower and cooling it down the resistance gets higher. This appears to make it an NTC thermister.
When I test the new Sensor it appears the cable is actually polarized. In one direction I get 5.3Kohms at 25 degrees and in the other direction I get 141 K ohms. at 25 degrees. (I suspext it's not a standard NTC thermister cable like the one it replaces. ....... )
The internal Circuit board is labeled CSC-v4 although the external label is V3.
On the internal circuit board there is a micro POT labeled 'roof'. But I have no idea what it does.
Twisting it violently to both extreams with the new cable installed doesn't seem to make a difference (neither does swearing at it, calling it names or threatening it with a pair of side cutters). I'm assuming its meant to be used to adjust the calibration, but without a technical manual for the product (and somebody to interpret them to easier non technical English for me) I am just guessing. In the picture, the IC4, beside the pot is labeled MAL - LM358N 90F836, in case it's not clear in the photo.
I'm hoping there is somebody here who can provide more information, or at least enough information to get our unit back online without spending huge amounts more money then we already have.
