Author Topic: Solder Fume Extractor VS Window Hose Pipe Ventilation Fan  (Read 556 times)
Offline jonovidTopic starter
    • JONOVID
« on: September 23, 2023, 12:45:41 pm »
why use a fan-forced activated carbon filtration unit whan a small ventilation fan, same vacuum cleaner hose pipe & window port will do.
we have kitchen range hoods & wood stoves have chimney pipes. so why not just add a plexiglass sheet
with an air port into a window as you would a window air conditioner. my lab room is well-ventilated room as it is.
so solder smoke is not a problem for the limited amount of soldering work I do.
I still wonder why so many soldering stations are in unventilated rooms with no accessible window?
requiring closed loop fan-forced carbon filtration units.
Hobbyist with a basic knowledge of electronics
Offline wraper
  • Country: lv
Re: Solder Fume Extractor VS Window Hose Pipe Ventilation Fan
« Reply #1 on: September 23, 2023, 12:50:36 pm »
Not a small fan, not a narrow vacuum cleaner hose and not everywhere you can put a window port without too much trouble.
Online NiHaoMike
    • Facebook Page
« Reply #2 on: September 23, 2023, 01:04:00 pm »
If the option is available, venting outside is a great choice. Put the fan on the remote end and the flex duct will substantially reduce the noise so that you can use a much more powerful one.
