Author Topic: Solar Cells  (Read 9367 times)
Offline RayJonesTopic starter
    • Personal Website
Solar Cells
« on: February 01, 2011, 09:07:02 am »
OK, I'm convinced I was conned.
I spied those ads on evilBay for solar cells, a shit load cheaper than pre-made panels and hey I can solder, I can do that, lets get some.
BAD IDEA.
These things are mega fragile, and if you even look at them wrong - crack - another cell rooted.
I did 9, then gave up.
Anyone else dealt with these devil spawn things and actually did all 36 without screwing them up?
Offline Polossatik
Re: Solar Cells
« Reply #1 on: February 01, 2011, 09:57:28 am »
no
 ;D
Also I've given up on that stuff for the moment, the "specs" are always way to "optimistic" or you pay trough the nose for ones that work at least a bit
Real Circuit design time in minutes= (2 + Nscopes) Testim + (40 +120 Kbrewski) Nfriends
Testim = estimated time in minutes Nscopes= number of oscilloscopes present Kbrewski = linear approx of the nonlinear beer effect Nfriends = number of circuit design friends present
Offline orbiter
  • -0 Resistance is Futile
Re: Solar Cells
« Reply #2 on: February 01, 2011, 02:17:58 pm »
Are you using the Monocrystaline type?
I've used quite a few of them and for me they're pretty tough, or perhaps I'm just too gentle with them :)
These... eBay
    • Personal Website
Re: Solar Cells
« Reply #3 on: February 01, 2011, 06:46:49 pm »
Poly's, and yeah if you feel the need to indulge in this foolish behaviour I'm now convinced - get the pre-tabbed cells!
    • Personal Website
Re: Solar Cells
« Reply #4 on: February 01, 2011, 06:51:15 pm »
These... eBay
Actually I note your ebay search was for *panel*, not *cell*.
Panels are easy - it is when you are dealing with the individual cells that life gets harder.
Offline sonicj
  • updata successed!
Re: Solar Cells
« Reply #5 on: February 01, 2011, 06:55:10 pm »
i have some, haven't tried it yet...
wire glue
*edit - mentioned on hackaday
« Last Edit: February 01, 2011, 07:08:24 pm by sonicj »
Offline sonicj
  • updata successed!
Re: Solar Cells
« Reply #6 on: February 01, 2011, 07:06:32 pm »
i've successfully used Caig Lab's CircuitWriter Pen to repair damaged traces on a membrane keypad. it was a PITA to accurately control the flow, but got the job done. not sure if this could be applied to solar assembly....
-sj
Offline glossywhite
Re: Solar Cells
« Reply #7 on: February 01, 2011, 07:19:39 pm »
I watched this video just the other day, and I wonder if it will be any help to you?:
Offline TopherTheME
Re: Solar Cells
« Reply #8 on: February 01, 2011, 07:31:43 pm »
wire glue
I've used this stuff for assembling small solar cells together and it works surprisingly well. I've also used it for gluing cracked fuel cell flow channel plates together along with joining low temperature components. The only downside is you've got to spend 30 minutes mixing the stuff before you use it.
Don't blame me. I'm the mechanical engineer.
Offline orbiter
Re: Solar Cells
« Reply #9 on: February 01, 2011, 07:33:32 pm »
These... eBay
Ah ok, Sorry my friend.
    • Personal Website
Re: Solar Cells
« Reply #10 on: February 02, 2011, 07:17:37 am »
Damn, I had all that gear in my shed and I still muffed it  ;)
Offline orbiter
Re: Solar Cells
« Reply #11 on: February 02, 2011, 11:21:34 am »
Briliant, thanks mate.. Saved it in favs for part of tonights viewing.
orb
« Last Edit: February 02, 2011, 01:16:08 pm by orbiter »
Offline Psi
Re: Solar Cells
« Reply #12 on: February 02, 2011, 12:05:32 pm »
I've used that brand of 'wire glue' before, you just have to be aware that it dries like plaster, not like epoxy, so it cracks really easy.
It doesnt really meet the definition of "Glue".
Offline Mechatrommer
  • Country: my
  • reassessing directives...
Re: Solar Cells
« Reply #13 on: February 02, 2011, 03:22:28 pm »
i have exactly this, 2 bottles. tried it to fix my keyboard flexi circuit, stir and mix it thoroughly, applied it, wait till dry, test the keyboard, no success, measured the connectivity, it only connecting at several MegaOhm iirc, not sure what i was doing wrong.
edit: 2 bottles, 1 opened, 1 still in the nice packaging. thoroughly checking, there are differences though, instead of just quick, simple, and reliable (as in picture), it has 4th... safe, Lead Free, not sure what good (or bad) it is, and the cartoon pictures are different, but the layout and arrangement is exactly the same, even the "No Iron" sign. site as on the label is at www.wireglue.us manufacturer Anders Products (Div. of Idolon Tech), 72 Stone Place Melrose, MA 02176... Patent Pending, email: info@andersproducts.com, dont know where the hell it is.
« Last Edit: February 02, 2011, 03:33:57 pm by Mechatrommer »
Offline rossmoffett
Re: Solar Cells
« Reply #14 on: February 02, 2011, 07:58:21 pm »
Wire glue is a mix of graphite and epoxy resin.  At best you can hope for 10-100 ohms of contact resistance, depending on the contact surface area.  I haven't had any luck with it either.  I'm sure there are uses for it, but for my purposes it was junk.  I was resonating a crystal and the resistance ruined my resonant circuit.
People who design circuits for use in clothing love the stuff, I've read.  They use it with conductive thread.
ArcAttack - A group of musical Tesla coil performers with semi-regular blog updates.
Offline TopherTheME
Re: Solar Cells
« Reply #15 on: February 02, 2011, 09:10:39 pm »
No wayyyy, if you're resistances are that high you're not using it correctly. Its typically about 1Ohm across each wire-panel junction when I've used it for solar cells. The resistance is high, but its not that high.
Offline rossmoffett
Re: Solar Cells
« Reply #16 on: February 03, 2011, 04:38:43 pm »
Well, that or I have some real crap wire glue.  I could never get the resistance below ~10 ohms with any amount of stirring.  Realize though that if you used a large surface area, not just the tip of a wire for example, that's what caused your low resistance.
