Looks nice so far. Not sure how wordpress is set up but you might want to consider breaking things up into separate pages. After half a dozen entries it seems like you'll have one seriously long page that will be tricky to navigate. Since I do pretty much the same thing as you, I might also suggest adding in some real butcher jobs you get to see. You know, the ones where some so called tech has been there before you and crowbared a fuse with a piece of tinfoil, solder blobs the size of walnuts, lifted pads, burnt wires etc. then you're left to clean up the wreckage afterwards. Or better yet, when somebody brings in a piece of gear that's stopped working and when you drop the chassis you find that some rodent has managed to inexplicably get inside the thing and chew through a few sections of hookup wire before getting electrocuted. Those are the ones I find particularly entertaining.
