Hi All,
I am brushing up my knowledge in Electronics and I am following the book 'The Art of electronics' 3rd edition. Could someone please help me to find out the solution for the following exercise from the same book.
Exercise 1.9 , Page 10 The very high internal resistance of digital multimeters, in their voltage-measuring ranges, can be used to measure
extremely low currents (even though the DMM may not offer a low current range explicitly). Suppose, for example, you
want to measure the small current that flows through a 1000MΩ “leakage” resistance (that term is used to describe a small current
that ideally should be absent entirely, for example through the insulation of an underground cable). You have available a standard DMM, whose 2V dc range has 10MΩ internal resistance, and you have available a dc source of +10V. How can you use what you’ve got to measure accurately the leakage resistance?
