Indeed, which seems to be the case here (the nearby DIP IC).
Hm, also there's six transformers but only four heatsinks, seems likely they're driven in parallel on the primary side, and that would make the job easier for a management chip too. Hm, I wonder if they're doing full bridge then, and varying frequency with PWM (phase shift PWM even?) or frequency.
Have also seen controllers (usually amounting to a simple buck converter or even plain fixed PWM into the supply inductor) used with oscillators. Doubt that's the case here.
