That looks about right for a Dell charger, I've taken apart a couple.
The silicone is used en-masse because chargers get dropped and shipping isn't always friendly, this reduces the chance of a fractured joint for some of the larger components. Also it probably helps damp any microphonic effects from inductors/transformers.
Probably a little excessive in your case but better more than less generally.
