Author Topic: Something interesting about frequency inversion  (Read 1615 times)
Offline Ben321Topic starter
« on: October 29, 2017, 12:17:48 am »
I was doing some experiments in this program I wrote that uses an FFT (via fftw.dll) to invert the frequencies in a signal. First I run FFT on a signal to get the complex spectrum of the signal. Then I invert the order of the bins in the spectrum. Finally, I perform the IFFT on the spectrum to get a time domain signal. However, something seems wrong. While the frequencies are in reverse order, the signal is also flipped in the time domain. I was able to correct this by performing a complex conjugate of the spectrum before performing the IFFT to get the frequency-inverted time domain signal. Now the signal is not flipped in the time domain, and it is frequency inverted as it's supposed to be.
So is this the correct behavior? Am I really supposed to need to perform a complex conjugate on the bins in the spectrum, as well as reverse the order of the bins, in order to produce a frequency inverted signal? Or is the fact that I need to use the complex conjugate (an additional step that I don't know if I should have to do) an indication that the FFT and IFFT algorithms I'm using (the ones supplied in fftw.dll) are themselves buggy?
Offline orolo
Re: Something interesting about frequency inversion
« Reply #1 on: October 29, 2017, 03:31:37 am »
I don't understand what you mean by "flipped in the time domain". So, I'm not sure if this is your problem, but my guess is: you have a real signal \$x_0, x_1,\ldots, x_{n-1}\$. You compute its Fourier transform \$y_0, y_1,\ldots,y_{n-1}\$. There is a well-known fact that, for real signals, the spectrum verifies the "conjugation condition" \$y_k = \overline{y_{n-k}}\$.
There is a subtlety. The "conjugation condition" does not reverse the bins of the spectrum, since \$y_0\$ stays unreversed. The conjugation means:  \$y_0, y_1, y_2,\ldots, y_{n-2}, y_{n-1}\quad = \quad \overline{y_0}, \overline{y_{n-1}}, \overline{y_{n-2}},\ldots,\overline{y_{2}},\overline{y_1}\$. This is due to the fact that from \$y_k = \overline{y_{n-k}}\$ follows: \$y_0 = \overline{y_n} = \overline{y_0}\$ (periodicity), \$y_1 = \overline{y_{n-1}}\$, \$y_2 = \overline{y_{n-2}}\$, etc.
So, if you completely reverse the spectrum: \$y_{n-1}, y_{n-2},\ldots,y_{0}\$, keeping in mind the "conugation condition", what you are really doing is the same as\$\overline{y_1}, \overline{y_2},\ldots,\overline{y_{n-1}},\overline{y_0}\$, that is, when you reverse the spectrum, you are shifting the spectrum one position to the left and conjugating it.
There is another interesting fact about the DFT: the time delay relation. If you shift the spectrum one position to the left, you are multiplying the signal by \$e^{\frac{2\pi i}{n}k}\$, and viceversa (changing left to right and the sign in the exponential). This means that, if you conjugate your inverted spectrum, all that remains is a shifted spectrum, so if you compute its inverse Fourier transform, you get the original signal multiplied by \$e^{\frac{2\pi i}{n}k}\$. This is what you mean when you say that inverting the spectrum and then conjugating it, you recover the signal without flipping?
If you do not conjugate the spectrum, there is no immediate inverse Fourier transform I can think of now (it's past 4AM here, maybe with a more clear head  :P ). The trouble is that, the inverse Fourier transform of a conjugate turns into a direct Fourier transform, \$\mathcal{F}^{-1}(\overline{y}) \ = \ \frac{1}{N}\overline{\mathcal{F}(y)}\$, so you wind up doing the direct Fourier transform of the shifted spectrum, not its inverse.
Hope this helps.
Edit:
Hmmm. Maybe this works. The inverse DFT verifies: \$\mathcal{F}^{-1}(y_0, y_1,y_2,\ldots, y_n) \ = \ \frac{1}{N}\mathcal{F}(y_0,y_{n-1},y_{n-2},\ldots,y_{2},y_1)\$.
So, let's compute the inverse DFT of your inverted spectrum using all the previous results. Let's begin with the inverse DFT of the reversed spectrum:
\$\mathcal{F}^{-1}(y_{n-1}, y_{n-2},\ldots, y_2, y_1, y_0) \ = \ \mathcal{F}^{-1}(\overline{y_1}, \overline{y_2}, \ldots , \overline{y_{n-2}}, \overline{y_{n-1}}, \overline{y_0})\$
This is due to the "conjugation condition", as we saw. Now, using that the inverse transform of the conjugate is the conjugate of the direct transform, divided by N:
\$ \mathcal{F}^{-1}(\overline{y_1}, \overline{y_2}, \ldots , \overline{y_{n-2}}, \overline{y_{n-1}}, \overline{y_0}) \ = \
\frac{1}{N}\overline{\mathcal{F}(y_1, y_2, \ldots, y_{n-2}, y_{n-1}, y_0)}\$
And now, using the above relation to turn the direct into the inverse:
\$\frac{1}{N}\overline{\mathcal{F}(y_1, y_2, \ldots, y_{n-2}, y_{n-1}, y_0)} \ = \ \overline{\mathcal{F}^{-1}(y_1, y_0, y_{n-1}, y_{n-2}, \ldots, y_3, y_2)}\$
Hm, no. We are back to the beginning, with a conjugate and two shifts to the right. I was hoping this would give a shifted spectrum, but it gives an inverted shifted spectrum. Maybe this is the flipping you were mentioning.
« Last Edit: October 29, 2017, 04:16:02 am by orolo »
