Author Topic: ESD Safe Hand Tools  (Read 6223 times)
Offline Tony RTopic starter
ESD Safe Hand Tools
« on: November 23, 2011, 01:36:01 pm »
So I came across some ESD safe screwdrivers, pliers and other simple hand tools, of course being ESD safe the price was inflated from that of normal tools. But I must ask, are they worth it for a hobbyist, or even industry?
http://www.amazon.com/Wiha-27390-Phillips-Screwdriver-Precision/dp/B001AN16QI/ref=wl_it_dp_o_npd?ie=UTF8&coliid=I1PPKG0MSNCLXZ&colid=2ZN3HX2L4S0UZ
http://www.amazon.com/Wiha-32790-4-Piece-Plier-Custom/dp/B000T9XVF8/ref=sr_1_1?ie=UTF8&qid=1322055264&sr=8-1
Tony R.
Computer Engineering Student
Focus: Embedded Assembly Programming, Realtime Systems,  IEEE Student Member
Offline steaky1212
    • Steaky - Sleep is overrated
Re: ESD Safe Hand Tools
« Reply #1 on: November 23, 2011, 04:18:24 pm »
Tony,
I wouldnt have thought you would need ESD tools. We only have anti-static wristbands and pads at work, but generally if you ground yourself out before touching anything you should be fine.
In fact, when working on hobby stuff at home I dont have any antistatic stuff - just try to ground out.
Saying that, apparently Wiha are a decent make... but I'd save the money for a decent DMM
Offline Rufus
« Reply #2 on: November 23, 2011, 07:14:18 pm »
What the hell is an ESD safe screwdriver? Ever killed a screw with static?
That said Dave seems to poke everything with a screwdriver, makes me cringe sometimes. For example around 5:20 in the recent Kindle Fire tear down where he pokes the contacts of an FPC he suspects is connected to the battery.
Offline sonicj
  • updata successed!
« Reply #3 on: November 23, 2011, 08:35:17 pm »
ditto! every time i see that screwdriver flying around the screen i'm tempted to forward a set of spudgers to OZ.
-sj
Offline steaky1212
« Reply #4 on: November 24, 2011, 01:38:07 pm »
Dave mentions about a little plastic screwdriver thing when talking about calibrating one of his new scopes
Offline don.r
« Reply #5 on: November 24, 2011, 11:51:16 pm »
Ceramic screwdrivers are great for adjusting pots and variable caps as they are both non-inductive and non-conductive. Only a couple of $ on eBay and you don't need more than 1 or 2.
« Reply #6 on: November 29, 2011, 07:27:04 pm »
I already have a Fluke 87, but this is more a general question.
What i am understanding is that they are more of a gimmick, sure they do what they say they will, but does one really need it.
I myself cannot see me buying a set any time soon, but how 'bout in industry? is there a benefit there?
Tony R.
alm
  • Guest
« Reply #7 on: November 29, 2011, 09:11:00 pm »
I guess there may be a point to removing anything that might create an electrostatic discharge from the bench. One thing I don't understand is ESD-safe tweezers. How can a regular pair of steel tweezers create an ESD?
Offline nukie
« Reply #8 on: November 29, 2011, 10:12:14 pm »
is antiESD tools a part of ISO certification requirement?
Offline Zero999
  • 0999
« Reply #9 on: November 30, 2011, 12:16:24 pm »
Yes which means all the tools have to be marked as ESD safe and brain dead auditors will pull you up on it if they find non-ESD tools in your toolbox even it shouldn't apply to them.
