Those wires were probably grounded. The helicopter is generating the static electricity. That's one of the issues with rescues at sea. Never touch the winch cable until after it has been grounded.
No it's live - those were clearly AC arcs. Static would just be a single spark.
Exactly.
Those lines are very much live. Grounding - or getting anywhere
near a grounded point would be catastrophic!!
They do live works as well. As long the chopper has the same potential as the cable, there's nothing to worry about.
That is why it is safe.
The capacitive current is lethal, but not a big deal for the chopper. The workers have metal shielded cloths so a few tens or hundreds of mAs through their body isn't a big deal either.
Hence why the initial approach is done with a wand. It takes the first arc strikes and then contact is made. At that point, the helicopter and everything on board is at the live voltage - with a bit of leakage to the atmosphere. While the wand is still in contact with the power lines, a hook is attached which ensures this contact is maintained during the process.
The work is then done. The hook is then removed - making sure the wand is still in contact with the lines and then the helicopter backs off, with the wand being the last thing to break contact from the power lines. The arcs then reappear until the helicopter is far enough away for them to cease.
If you follow the process correctly, it is quite safe. Your biggest risk is wind gusts on the helicopter.
