Author Topic: Spacex Starship IFT-2 launch today  (Read 4581 times)
Offline wraperTopic starter
  • Country: lv
« on: November 18, 2023, 11:12:04 am »
Starship IFT-2 launch will happen today at ~ 7 a.m. CST / 8 a.m. EST (1300 UTC) (in less than 2 hours from posting this).
https://twitter.com/i/broadcasts/1dRKZEWQvrXxB
« Last Edit: November 18, 2023, 01:08:14 pm by wraper »
Offline Dan123456
Re: Spacex Starship IFT-2 launch today
« Reply #1 on: November 18, 2023, 12:43:06 pm »
Are we taking bets on how long this one takes to explode?  :-DD
  • Country: lv
« Reply #2 on: November 18, 2023, 12:48:30 pm »
20 minutes
Offline Dan123456
« Reply #3 on: November 18, 2023, 12:49:29 pm »
1 minute
Lol  :-DD
I’m hoping for detonation while still on the pad personally  :-DD
Edit: Awwwww :( Hopefully next time they blow the pad up along with the rocket  :-DD
« Last Edit: November 18, 2023, 01:17:33 pm by Dan123456 »
  • Country: lv
« Reply #4 on: November 18, 2023, 12:51:48 pm »
1 minute
Lol  :-DD
Effing scammer channel impersonating Spacex got me :palm: when I searched for Spacex channel a bit before supposed launch, they put stream from the last launch and started their scam at the supposed liftoff.
EDIT: Apparently SpaceX streamed on Twitter only and crypto scammers made a good use of it.
« Last Edit: November 18, 2023, 01:23:53 pm by wraper »
The following users thanked this post: Dan123456
  • Country: lv
« Reply #5 on: November 18, 2023, 01:06:57 pm »
Booster RUD but Starship is going
« Last Edit: November 18, 2023, 01:14:38 pm by wraper »
  • Country: lv
« Reply #6 on: November 18, 2023, 01:17:30 pm »
Well, at least it got into space.
The following users thanked this post: AlbertL
Offline AlbertL
« Reply #7 on: November 18, 2023, 01:35:49 pm »
And, the launch pad survived!  I think.
Offline Psi
« Reply #8 on: November 18, 2023, 01:52:01 pm »
One really important achievement for them was this full duration burn of every single booster engine. Every engine lit and not a single engine shut down.
Raptor engine reliability is critical and they seem to have made HUGE progress on that since the first launch.
Completing hot staging is also a great milestone.
Seems likely it may have damaged the top of the booster and caused the RUD, but still great progress getting separation.
The reason for the starship RUD right at the end of the burn isn't so clear, we will have to wait and see.
« Last Edit: November 18, 2023, 01:57:04 pm by Psi »
Offline rdl
« Reply #9 on: November 18, 2023, 02:18:10 pm »
Amazingly successful test flight.
That Super Heavy Booster was beautiful with all those engines burning.
Thumbs up SpaceX.
« Reply #10 on: November 19, 2023, 09:26:48 am »
Next stop, the year 2022 and a colony on Mars!
The following users thanked this post: vk6zgo, Dan123456
Offline Psi
« Reply #11 on: November 19, 2023, 10:19:14 am »
Speculation is that the relight of the booster engines happened without stable acceleration to keep the fuel from floating/sloshing around in the tanks and many engines inhaled air and exploded. Resulting in an inability to continue the booster return and water landing mission, which triggered FTS.
« Last Edit: November 19, 2023, 10:22:10 am by Psi »
Offline m98
« Reply #12 on: November 19, 2023, 12:42:03 pm »
Before that, we must stop in 2017 with the first crewed flight test of Boeing Starliner...
The following users thanked this post: wraper
  • Country: lv
« Reply #13 on: November 19, 2023, 12:55:21 pm »
For 2x the money that SpaceX received for Crew Dragon.
Offline AndyBeez
  • Country: nu
« Reply #14 on: November 19, 2023, 01:17:08 pm »
The launcher not only has to take on board enough fuel to insert the payload into low earth orbit but, the stages need enough fuel for the soft landing return. This makes for a 'dead fuel weight' overhead on the way up. Maybe the engineering horizon for this added mass is too far away at this scale?
A fully reusable launch system might be 'green', but cannot be sustainable when confidence of delivering an expensive payload /personnel into orbit is currently less than zero - despite all of the optomistic hollowing and whooping from the Muskovites every time the glue comes unstuck.
On a side note, I recently heard the Nasa versus SpaceX dynamic being described as, "it's rocket scientists versus space cowboys." Yee har...
  • Country: lv
« Reply #15 on: November 19, 2023, 01:37:33 pm »
This year "space cowboys" put 4x more mass to the orbit (1000 tons) than the rest of the world combined. Also they are the only US launch provider that can currently deliver astronauts to ISS (for NASA you just mentioned).
  • Country: lv
« Reply #16 on: November 19, 2023, 01:51:32 pm »
Not to say since 2017 they had about 245 successful launches in a row which is absolutely unmatched reliability, F9 B5 (introduced in 2018) and Falcon Heavy had zero launch failures.
Offline Stray Electron
« Reply #17 on: November 19, 2023, 05:56:45 pm »
     That shouldn't have been a problem.  Ullage engines have been used for MANY years to provide a slight amount of acceleration so that the fuel and oxidizer are pushed to the bottom of the tanks so that they will be properly picked up for engine re-ignitions.
Offline iMo
  • Country: va
« Reply #18 on: November 19, 2023, 07:02:13 pm »
Fantastic launch! All engines of the booster worked fine, the switching off sequence was impressive (look at the slowmo sequence)..
A significant achievement, imho..  :clap:
Online tom66
« Reply #19 on: November 19, 2023, 07:25:58 pm »
I think this could be a factor.  If you look at the stream on Twitter, you can see that the engine 'diagram' shows many engines failing before the RUD.  Also, you can see debris coming off the top of the rocket. It's possible that a few engines failing next to each other damaged critical hydraulics or avionics and loss of control occurred leading to FTS.  Not sure if FTS is done by Range Officer or is fully automated on SpaceX rockets.
Offline DavidAlfa
« Reply #20 on: November 19, 2023, 07:33:36 pm »
3...2...1.. Boom? Weird, didn't!
Damn, let's give it 10 seconds... still...
Wait separation, for sure will instantly blow apart... Nope!
However patience and perseverance always pays off, we all know Musk spends 50% of his time talking nosense in X, probably busy in some stupid woke thread so was unable to push the button earlier!
Damn it, almost forgot! *click*
« Last Edit: November 19, 2023, 07:36:16 pm by DavidAlfa »
Offline SiliconWizard
« Reply #21 on: November 19, 2023, 11:43:47 pm »
Indeed.
Offline coppice
« Reply #22 on: November 20, 2023, 12:11:31 am »
The booster was twisting around at the time, which makes it pretty hard to get the fuel in the right part of the tanks. Most rockets which start twisting around quickly trigger their self destruct. This is not uncharted territory for Space X, though. This is an issue they also face with the Falcon, where they seem to have it sorted out very well. You might have expected them to have carried over what has proven reliable there, and nailed this on the first try.
Offline coppice
« Reply #23 on: November 20, 2023, 12:16:50 am »
It seems more likely the engines didn't fail, but were starved of fuel. Once things get a little unstable tons of fuel hammering around in the tanks can soon break them up. You could see just before separation that they didn't just shut most of the 33 engines down in one go. They cut them in small groups, so the fuel flow didn't come to a shuddering halt, and act like a hammer to smash up the ship
  • Country: lv
« Reply #24 on: November 20, 2023, 12:18:42 am »
It's very different from Falcon though. Different fuel, very different engines with different ignition mechanism, autogenous pressurization instead of helium, pretty much uncharted territory in every corner.
