Memory16 kpts (2 channels)
8 kpts (4 channels)
This is really bad. Really bad today.
also 320x240 pixel monitor.
is it really today? Yes it can use but after one time looking 7 or 8" 800x480 or 800x600... there is no road to back.
I agree that memory depth is quite limited compared to the current two channel scopes. Since you clearly believe that the only low-end scopes worth buying these days are made by Owon, which four channel Owon scope would you recommend instead? What other affordable four channel scopes with 1M+ memory and better than QVGA resolution are currently available?
Exactly no. I only tell that this memory is tiny and display is littlebit small size but more bad it have also very low resolution.
In this price if really need 4 channel, maybe can live with this display and memory. This price is nice.
But it need realize that sampling speed go slow very fast with this kind of memory with lower horizontal speeds so that there do not then come disappoint in real life. (example with aliasing)
If want more there need jump markable higher price.
If have this posibility in budget, then there is selectable many very good candidates.
One example is this: HMO724
(as I say, one example. There are many and this example may be not best. Also what is ok depends lot of what is really need)
