General => General Technical Chat => Topic started by: Homer J Simpson on November 24, 2024, 07:47:44 pm
I was searching for a set of these and wanted to share in case anyone else finds it useful.
Set of lead forming tools from a company called ProbeMaster. Some other interesting items on their site as well.
https://probemaster.com/speedy-bend-resistor-lead-forming-tool/
Edit - Adding Sanhayat Lead Bender RB-5.
https://shop.sunhayato.co.jp/en/blogs/problem-solving/lead-bender
Also many variants on Thingiverse
That looks like something a DIYer could easily make out of wood with mostly just a saw.
Looks useful.
I have a few of these, but I've always found that they don't work any better than pliers.
Unless you have to bend hundreds/day; is a semi-mass(up to 10's of boards/day) production tool.
These tools work well if you are soldering axial-lead components to breadboard-pattern perfboards that have 0.1 inch hole spacing.
Here are STL files for several resistor lead benders I downloaded from Thingiverse if you don't want to do a bunch of searching. They work well if you have a lot to do.
I won't spend $10 for one! But did print a couple for 10 cents.
