Hello
just evaluating a possibility to use a Speex codec in an embedded application.
https://speex.org/There are Win32 CLI tools available for download, that would be a very helpful for debugging stuff and generating sample files. However those damned CLI apps do not work. Whenever I try to encode anything, the encoder tells me it starts encoding (or decoding) and then it crashes. Doh!
Here is the download link for the binaries:
http://downloads.xiph.org/releases/speex/speex-1.2beta3-win32.zipTried on two different computers running W7 x64.
Does anyone have any of these binaries actually working? Or what might be the problem?
I have only found a brief mention of the problem from May 2009:
http://lists.xiph.org/pipermail/speex-dev/2009-May/007223.htmlThank you for help,
Yansi
PS: Supplied you a sample wav file if you dare to try yourself
//EDIT: Finally found the 1.0.4 binaries seems to work. Dammit! Sad they couldnt repair the bloody 1.2b3 since 2009...
