So this is a controller for a old MIG welder.
The 555 circuit on the right, together with the two darlingtons, is providing a 1KHz PWM control for the speed of the welding wire feed.
The 555 circuit on the left is for pulsed welding, so a pulse of 2 to 0.5Hz, so it switches on-and off the welder (and the PWM)
I cannot for the life of me figure out what the function of the top transistor is supposed to be.
It looks like a standard half H bridge, but if you look better, it does not fit, because there is no need to feed +30V into both sides of the motor.
Under ideal conditions, it turns on when the bottom turns off, like a H bridge, so not a problem. But what is it supposed to do?
Some snubber for the motor? The diode already does this. It does not drive anything? Well, in fact, it drives a short when the bottom transistor also turns on.
It is a problem, because everything is not ideal, the reset signal of the 555 takes some time to propagate, and during the transistor swapover it briefly shorts.
This eventually burns out the the transistors. If a simply leave out the top transistor, everything simply works.
Which is BTW also how I found the problem: After decades of working well, the welder stopped, and I discovered both transistors burned. I replaced them both, and it all worked a few days, and then burned again
So again, if I leave the top transistor off, it all works.
And now I suspect that is how it all worked all those decades. Top transistor was probably broken all this time, I should only have fixed only the bottom one
But what is the top transistor even supposed to do ?!?
See attachment
Also I have been playing with falstad simulator.
https://tinyurl.com/2f8poj3o
