For the glass cover of the solar powered version, we can offer different types of slip protection depending on the customer's requirements. It is possible to create different ribbed shapes and patterns. Alternatively, Al2O3 can be applied and burned into the surface, which offers permanent slip protection. Due to its basic physical properties, this substance can generate sufficient friction in both wet and dry weather. If the above two methods are not feasible, a special transparent hydrophobic polymer can be applied to the glass, creating a hydrophobic layer that prevents water films from forming between the sole of the shoe or the car tire and the glass, resulting in a non-slip surface .
